yellowss7
  1. Steve have you started the polishing yet? I CAN'T WAIT to hear that lovely crossflow again. :driving::seeya: Although I hear that The STIG's car may be giving you a run this year for the Shine Award. :leaving: Tom
  2. Croc, I've used both the CR500's and the R888's and both give good street and track performance. R888's are significantly heavier than the CR500's. Tom
  3. Just an update. We now have 17 Drivers who have submitted their info and have indicated that they are planning on attending the event.:hurray: We also have 3 or 4 spectator groups that also have declared their intent to join us. Those of you who are still thinking about joining us still have time to get your cars ready. We are just over 2 months out. The track has not yet opened registration for the event, but we expect that to happen in the next two to three weeks. We will email you the information when it becomes available. So start shining up your se7ens! :cheers: Tom
  4. Karl, maybe you can reskin your Caterham in polished copper to match the still. :troll: Tom
  5. Karl, you are a genius! That means that the new corner weighting and upgraded brakes would be a "business expense" Sounds like the addition of a Supercharger also fits the Business model. :cheers: Tom
  6. I get 10 or so trackdays, 4-5, 25 minute sessions, on my soft R25B compound hoosiers. They still have plenty of rubber left, but they seem to get a bit harder and slower. To keep up with the big dogs, I change to a new set. 40-50 heat cycles is unheard of for heavier cars.
  7. Slicks are slicks as far as I'm concerned. I've been running the same Hoosier R25Bs that I use to autox on and I've been very pleased with the grip and how they last. The FA's might be a little harder, but it's going to be July so Global warming probably will be in full effect by then, and they should be fine as well. Either set should give you a tremendous amount of grip. This is all about being smooth compared to autoxing that requires a bit more unsettling the car IMO. You will be progressively ramped up on speed, and confidence as the sessions progress. You won't be out to set the track record on the first day.:driving: Pick a set and have fun. Tom
  8. Roman, no track experience is required to run in the Novice (green) run group. Instruction and instructors are provided, and you follow a pace car to learn the track and lines thru the turns. No passing is allowed so you can concentrate on driving and learning the track. It's a great way to get track experience in a safe, progressive fashion. You will pick it up quickly as the track doesn't change, unlike an autox course. Tom
  9. Yeah, that's probably the smart move, but I've had the car for 14 years now. I built it and as you know it's been VERY reliable for all the years on track and autoxing. I have a special attachment to it. Plus I like Clams. :jester: So yeah, financially it's probably smarter, but not many have accused me of being smart. :svengo: Tom
  10. Hey Mike, I replaced the head gasket and followed all the steps recommended by Dave Andrews, the UK Kseries guru. Checked liner heights, Peened the fire rings, did a light skim, used new head bolts and the recommended gasket. Oh, and replaced the plastic locating dowels with the upgraded steel ones. Dave said those steps should ensure future reliability. Couldn't find any sign of a breach in the gasket, but Dave said that it's not always easy to spot. I was surprised that it still had the old style plastic dowels, but knock on wood, everything is good now. The car ran great and coolant levels and temp were perfect. I did buy a new Duratec on Ebay in the fall. Just trying to figure out what power level to take it to. I talked with Jon Nelson last week and he thought the 263hp R500 level was a good compromise. It's either around 225 with no bottom end work or whole hog is around 290-300hp. I picked up the Duratec because it was a great deal. Unfortunately, to switch to the duratec, it requires all new mounts, bellhousing, exhaust, clutch, TB's ECU, loom and ancilliaries, before I even think about internal work to get the big power. Just have to determine how much pain I want to endure trying to convince the wife I need to spend the bucks needed to do it right. Luckily the current engine is running great, it's just not quite able to keep up with Blubarisax and Croc or the other Big Dogs on the track. Yesterdays frustration was the inability to hold off a GT2 Porsche on the track. Had him on the turns but he ran me down and over on the straights. Another 100hp would probably have help me. :jester: Happy Easter. Tom
  11. Sounds about right. Can't wait to see what changing over the front hubs and stub axles for the upgraded one will cause to fail. :svengo::toetap05:
  12. Took the Caterham to the track on Friday for a couple days on the track. After 14 years, about 60++ trackdays and 8 years of autoxing, I finally put new pads and front rotors on. :svengo: Funny thing is the pads still had plenty of life left in them. Gotta love light cars. I knew that the pads needed to be bedded in, so I did a few 30 to zero stops in the paddock and went out in the first heat figuring I'd have a chance to do the 70 to 30 stops under the first lap yellow. Got in at the back of the pac and on the first straight got up to 70ish and hit the brakes. WHOA NELLY. Locked them up and had to hold on as the car made some wild gyrations. Did it again on the next two straights and had similar reactions. Pitted and joined the group at the back end again and did three more similar braking applications and it seemed to respond better. Did the next session and all was good. Third session, the car wouldn't start. Seems that Alternator went tits up and drained the battery. Done for the day. :nopity: Charged it overnight and it started up and ran great for the session. Put it back on the charger and Nope it wouldn't start. Charged it again, and got another run in and called it a day. Felt good to get back on the track, and the car felt good and I got a good workout getting in and out with the new rollcage. Guess you got to take the good with the bad. Tom
  13. Good response so far, 15 drivers and 3 spectators have provided the requested info. Still hoping for 8 more potential drivers and a couple more spectators to respond based on the original interest. I'm hitting the track tomorrow and will turn in the first batch of driver histories to the track Admin. Tom
  14. I have a 280 MOMO that gives good leg clearance. Nice thickness for good grip as well. Tom
  15. Shane, you best watch out for Kitcat and don't let him get behind you. His nickname from our first outing was the "Blue Enema" :driving: He'll run right up your rear. :smilielol5: Tom
  16. Mario, most people will arrive late afternoon on Thursday July 3rd, we will have a BBQ dinner that evening. Friday, July4th, Breakfast starts at 7am with Tech opening then as well. Drivers meeting begins at 8am. Track goes hot at 9am. I don't have details on our run group timing at this time. Lunch is usually scheduled around noon, and is included in the fee. Saturday July 5th's schedule will duplicate Friday's. Sunday July 6th we will host a Karting event in the morning for those that wish to participate. So depending on your schedule availability, those are your options. Cost of the track days has not been released as of yet by the track but Last year's guest fees were $195 per day for drivers and $25 a day for non driving guests, both include a buffet breakfast and lunch and liquid refreshments during the day. NJMP Drivers club is the event organizer. They have granted us our own Run Group for 7's only. Race tires permitted for Caterhams only. :smilielol5: You stalker boys can either run with 4 plug wires disconnected or run on 6 inch wide bias belted tires your choice. :smilielol5::jester: Passing is on the straights only with a mandatory point by. This is NOT a race. Tom
  17. Shane, you might want to consider something like this and add an anti sway bar to it as well. http://www.ebay.com/itm/66153-Reese-SC-800-lbs-Trunnion-Bar-Weight-Distribution-Kit-Sway-Control/290971460204?_trksid=p2047675.c100011.m1850&_trkparms=aid%3D222008%26algo%3DSIC.MOTORS%26ao%3D1%26asc%3D21398%26meid%3D6187317375988238428%26pid%3D100011%26prg%3D9407%26rk%3D5%26rkt%3D10%26sd%3D180872918771 Tom
  18. Thanks Stewart, got it! We now have 12 drivers that have submitted their info, and we received 2 more responses from potential attendees who are not driving but possibly attending. Still looking for the other 11 drivers to submit their info and 4 other non driving spectators to just confirm they are coming. Tom:party:
  19. Thanks Martin! you may be in the Pole Position with that resume!!! :cooldude::cooldude: Tom
  20. Thanks SteveN., Kitcat, MichaelD, Steve M. and Dave D. Info received. Keep them coming. :hurray: Tom
  21. Thanks Shane. Got it. keep them coming in. Tom
  22. We are now 90 days out from the 4th Annual East Coast Sevens Event at New Jersey Motorsports Park. Hopefully, you have cleared your schedules to attend July 3rd to july 6th, 2014, Mike and I are very much looking forward to seeing you all. Online registration is expected to open in mid-May. To get a head start on the process we need your assistance. So we can send you an online registration hyperlink we need you to send an email to sevensarefun@gmail.com with the following information: 1) Your name and anticipated family/guest numbers attending. 2) Contact phone number 3) A driving resume for those planning to HPDE their seven – one or two days As you will be participating in an NJMP-sanctioned event, they require a driving resume/history to make sure that you are eligible for participating in a passing run group. The summary should contain: · Your name · Track experience (HPDE, racing, time trials, hill climbs, etc.) · Number of events participated over time · Tracks you have run at · Copies of racing licenses or past racing experience, if applicable. This is not intended to be a multi-page life history but a short history to show that you have driven on track before and are qualified to be in a passing group. Once you have emailed them to sevensarefun@gmail.com, Tom and I will submit the resumes to NJMP in advance for review. Please be sure to send your email to sevensarefun@gmail.com otherwise we will not be able to send you the appropriate online registration link and you will not be registered to participate. Those of you with limited or no prior track day experience may be placed in the non-passing, GREEN run group which is a great way to ease into an on track experience. This group runs behind the pace car and allows you to learn the track and the speed is progressively increased throughout the day. Best bit is that you still get to join in all the social fun in the pits between driving sessions. Given the proximity of Millville to the Jersey Shore and that we are having this event on a holiday weekend, you would be well advised to starting planning lodging accommodations. Below is a list of popular options: · Trackside Suites at NJMP/NJMP Villas http://www.njmp.com/accomodations/#vipsuites · Marriott Fairfield Inn and Suites http://www.marriott.com/hotels/travel/aiyml-fairfield-inn-and-suites-millville-vineland/ · Hampton Inn / Holiday Inn Express / Wingate by Wyndham 15% discounts for NJMP patrons here http://www.njmp.com/accomodations/exclusive-hotels/ · Days Inn http://www.daysinn.com/hotels/new-jersey/vineland/days-inn-vineland/hotel-overview · Quality Inn http://www.qualityinn.com/hotel-millville-new_jersey-NJ004?sid=xtqQni.r2E6IgSpbg.27 · Ramada Inn http://www.ramada.com/hotels/new-jersey/vineland/ramada-vineland/hotel-overview For those of you that are into camping or have RV campers, on site camping is permitted for a small fee to cover electrical hookups. Following is a list of those who had originally expressed interest in participating. If your plans have changed and you are no longer able to make it then we understand, just let us know so we can plan accordingly. Attendees from the original Save The Date forum post: 1) Yellowss7 (Tom) Caterham Info received 2) Croc (Mike J.) Caterham Info received 3) Blubarisax (Karl) Caterham Info received 4) JBH (Jeff H.) Caterham Info received 5) Kitcat (Mike M.) Caterham Info received 6) Michael D (Michael D) Caterham Info received 7) Sabbot (Stewart) Caterham Info received 8) BBall7754 (Steve M.) Caterham Info received 9) Dave D (Dave D.) Superformance S1 Info received 10) Jeff S (Jeff S.) Caterham Info Received 11) S1Steve (Steve N.) Superformance S1 Info received 12) EvilRomeo (Roman) WMC Ultralight Info received 13) Iceberg1234 (Paul B.) Birkin 14) Xcarguy (Shane) Stalker V8 Info received 15) 4Mario ( Mario) Stalker V8 Info received 16) SK400 (Sebastien K.) Caterham Info received 17) Len C. (NJMP member) Caterham Info received 18) Andy B. (Andy B) Caterham 19) Poorichard (Richard) Stalker 20) 951n914 (Scott L.) Caterham Info Received 21) The Stig (Martin) Caterham Info Received 22) Klasic69 (Michael G.) Caterham Info Received 23 Red Duck (Steve) Caterham Info Received 24) Wemtd ( Spectating) Info Received 25) Paul H. (Spectating) 26) Boxlogist (Spectating) 27) Werthie (Possibly spectating) Info received 28) Simon W. (spectating) Info received 29) Pe7e( Pete B.) Caterham info received
  23. Fixed that for you. :jester:
  24. Steve, the Villas are really close to Croc's new garagemahal. So close You could probably hear him snore at night.:jester:
  25. Sorry to hijack this thread. the Villas are individual condo units and I think have 3 bedrooms. Very nice. The Suites are the other track option and are basic, with two nice pull out beads. That are actually comfortable. They run around 70plus a nite if I recall correctly. The Hampton is nice and is about 7 miles away. the Fairfield is about 2 or 3 miles. Hampton is a little nicer IMO, but both are good. Haven't stayed at the Wingate, but it's in the same lot at the Hampton. Haven't done the Holiday INN either and that's about 3 miles away.
