Going coast to coast without a clue
SanderGA
  • Replies 94
  • Created
  • Last Reply
Top Posters In This Topic
I assume it has a thermostat but I don’t know for certain. The behavior does seem odd. If it has a thermostat and it closes the water flow it should heat up nicely. It’s odd that doesn’t happen. I’m going to check that."
That would also explain why your heater does not work well! Mine will put out plenty of heat. Colin liked to keep his feet warm......
Here's a summary of what I needed for the trip. This will be my packing list going forward. Items marked with an * are items I didn't have but will take next time.
Great weather. I did 20 days without a drop of rain. I was so lucky in that regard
A car in good shape. I was fortunate the car I got was well maintained. Honestly, it was crazy to do the trip in a car I hadn't done a shake down run with and gotten familiar with. If I had owned the car for six months and driven it before this trip, none of the problems I encountered would have happened.
Doors, sunglasses and ear plugs
AAA membership. I thought I could get this last minute. You can but only the basic level which offers a 7 mile tow. To get the high-end AAA membership you have to be a basic member for 90 days with zero tows. After the 90 day period, you can upgrade to the membership that offers tows of up to 200 miles.
Here's a list of tools I ended up with:
Socket wrench
Metric and imperial sockets
Metric and imperial wrenches
Vice grips
Screwdriver with interchangeable tips
Stubby screwdriver for removing the nose
Hex keys in metric and imperial
Pliers
Needle nose pliers
Wire snips
Torx wrenches (there are no torx fasterners on the car but as I change things out, I add them because they are so much better than the alternatives)
Blue lock-tite
Zip ties
Thin and thick sharpie
Crescent wrench
Air pressure gauge which I now use at least once a day
SAE powered electric pump
Jack and tire changing kit including any necessary key to remove the wheels
Baling wire
Duct tape
Voltage tester
Test lead
Wire stripper, cutter, crimper
A couple of inline fuse holders
A couple of switches.
Ring and spade electrical connectors
Butt connectors
18 gauge wire in a couple of colors
A charged cordless drill with drill bits (seems excessive but was a huge help)
Replacement bulbs for headlights, tail lights, turn signals - Test all lights before the trip
Fuses
Fuse puller
Map of fuse placement in the fuse box
At least two SAE plugs connected to the battery, fused and run to the cabin and one with an in-line switch
SAE to USB converter to power my phone (Note these will drain the battery over time so pull it every night or switch it off.
Quadlock windshield phone mount, Quadlock phone case and Quadlock wireless charging head
Spare phone with SIM card from provider
Spare eyeglasses
Eyeglasses leash to keep them from blowing away
Consumables and spares
Oil as I burn a quart every 1,500 miles
Clutch cable
Throttle cable
Brake fluid
Rags
Nitrile gloves
Slime and/or tire plugs
Waterless hand cleaner
Something to clean the windshield
Silicone tape for bad hoses
Gas can, funnel and siphon
I hope this list is helpful. Feel free to add anything I didn't include that you would feel is helpful.
For what it is worth, I think you did the right thing and took the right amount of stuff. You reminded me that over-planning can get in the way of a good adventure and that is something I really don't want to forget.
I was smiling as I shared your adventure with my wife.
Speaking of adventure, highly recommend the documentary on Amazon about Horatio Jackson's experience:
https://www.amazon.com/gp/video/detail/B08CW35KY7/ref=atv_hm_hom_1_c_ET3Pyw_brws_5_4
  • 6 months later...
15 minutes ago, Kitcat said:
I think someone shrunk your Caterham
I had wondered that and then I found the explanation. A few weeks ago the Bidens visited the Carters and they posed for a photo with the Carters in the middle and the Bidens on either side. The Internet blew up because the Carters looked like little-people next to the Bidens, who looked like giants. Turns out, a wide angle lens makes objects on the edge of the photo look larger and objects in the center look smaller. While this photo is unedited, I think that may explain the disparity.
My wife has a Palisade (SUV on the right in that photo).  Scaling seems accurate to me.   Not to hijack the thread and have someone report me to the overly zealous admin, but...
12 hours ago, panamericano said:
Who's got a photo with semis?
Your adventure looked awesome, my turn next!
Taking mine to work for now. I sure like the contrast!
