Still, top down motoring...hope she enjoys it.
Yes, this is a full on smog edition, single carb, all the air pollution controls, 53 BHP model with, as noted, the rubber baby buggy bumpers. Although many late model spitfires have those converted to earlier style chrome bumpers it is thought to be sacrilege to do so to this final model year. Speaking of which, with its build date being June 1980 and the last UK model being built in August of 1980 that makes the wife’s car one of the last North American Spitfires to be assembled. It was bought new in February of 1982 so it is also one of the last Spitfires sold. As to the fuel issue the garage discovered a cracked rubber fuel line and thought it was sucking air. This after the car lost almost half a tank of fuel while it sat waiting to get looked at. Sounded plausible and the car started and ran fine for them after they replaced that hose. The mechanic did adjust the carb and reset the timing as well. However the carb needs a full rebuild so a kit is on order. We picked the car up late Friday and the wife drove it home. When we arrived she jumped out screaming it was on fire. I raised the bonnet to find it was just coolant burning off the exhaust manifold. When she went to restart it so I could look to see where it was leaking, you guessed it, it would not restart. She washed and detailed the car. That took about two hours at which time it fired right up and she drove it into the garage. Go figure, eh! The car sat all weekend as it rained off and on. Yesterday, (Monday) she decided she wanted to drive it over to the nearest gas station to add some carb/injector cleaner and fill the tank up with fresh fuel. It fired up and drove over without incident. I took a can of Quick Start just in case it wouldn’t start. I figured it should fire up with a squirt of that stuff. However, it didn’t start after filling up nor after waiting several hours regardless if I used the Quick Start or not. So, Hagerty roadside assistance came in handy yet again. The car is now back at the shop and the wife doesn’t want to see it until they can prove it will start repeatedly whether within minutes or hours of being shut off. I’ve researched this issue and it seems lots of Spit owners have had this very problem before. However, each seems to have had a different cause and therefore needed a different solution. From carb rebuilds or replacement to filters and switching to electric fuel pumps. Then there are the electrical fixes from bad earths to lose or broken wires to replacing the coil. I’ll keep you informed as to what the problem and cure is/was. Meanwhile, I’m off in a couple of hours in Purple Reign to the Tuesday night cruise meet about a half hours pleasant drive away.
Shame to miss you on the route. I finished my trip and made it all the way to LA - a little over 3500 miles (with the Boston leg). Was a great trip. Had a little detour up to Vegas. Highlight of the trip, driving wise, was the mountain pass going into Oatman. If I wasn't if a time crunch, I'll probably have repeated that section :-). The town/village of Oatman was amazing to. Ended up with a little bit of sun burn on the last couple of days but generally did pretty well. The 7 was amazing. Everyone always asked if I was comfortable - I'd tell them my back was genuinely better than it was when I started! No major issues on the trip. Somehow lost the "7" grill on the nose cone somewhere around Oklahoma - not sure if it fell off or was stolen and the nut holding the door fastener on drivers side fell off. The door pins didn't like highway speeds and tended to vibrate up and out of place. But otherwise a pretty smooth journey! Now I just need to trip down 3 weeks of 360 video footage from the trip!
Greetings (sorry for the long rant): I've read this thread and a few others that touch on brake issues / problems I'm experiencing and my questions, so I'm posting here. This is after talking w/ AP Racing, Caterham, Demon Tweeks, Questmead, and researching AP documents as best I can. But of course, I may have missed something so defer to the collective group wisdom which greatly exceeds mine. Does anyone have direct experience replacing the "STD" 0.700 bore brake master cylinder w/ the "AP Racing" 0.812" (13/16") bore brake master cylinder, or associated driving experience / feel to offer comparisons 0.700" to 0.812"? The line pressure comparison data etc. AP offers would indicate going up in bore size would reduce feel and the ability to modulate pedal pressure etc. Seams counter intuitive to go up in bore size. I should be able to answer this question myself but am currently trying to remedy / fix brake issues on my: 2008 Roadsport S3 Duratec (0.700" bore brake master cylinder CP5615) repair kits are unavailable so I need a new brake master cylinder, front brakes finally bit the dust as the whole travel to cut off thing, seal degradation, shimming etc. apparently does not allow the port to the hose / reservoir to open upon pedal release, the pads cannot be fully retracted nor can I bleed the front brakes, even with the pedal detached to not preload the cylinder. Rear brakes work fine and can be bleed. The brakes have never really been to my liking. Trying to decide, if I have to buy a new brake master cylinder, should I stick w/ 0.700" bore ($$) (repair kits unavailable) or go w/ the 0.812" (13/16") bore ($$$+) "AP Racing Brake Master Cylinder" (repairs kits are available). Note I have yet to remove, disassemble, and inspect the master cylinder, so do not preclude the potential for a broken internal spring or other problem. 2005 CSR 200 (0.812" 13/16" bore brake master cylinder "AP Racing" CP4627) CP4627-18RK repair kits are available. The brakes work (considerably better than my S3), but given recent experience driving a couple Caterhams with incredible brakes in the UK, and after cleaning, checking, and bleeding brakes my CSR brakes, I have decided the brake master cylinder needs to be rebuilt. I've attached the CP4627-18RK repair kit info including schematic for reference. As best I can tell the 0.700" bore brake master cylinder CP5615 internals are similar but I welcome any corrections. Note: Both cars have the uprated 4-pot Caterham / AP Racing front calipers and stock rear calipers (Sierra?). Anyone with experience or knowledge about the above who can provide any insight or recommendations would be greatly appreciated. Cheers! Steve P14.038.pdf - Today
Hey Terry, I am going to have the 7 out this weekend, may go for a short drive with another 7. You're welcome to come by Saturday. I'll PM you my address.
slowdude started following Route 66 Road Trip
I wish I had seen this earlier. I just got done with a 2.5 week chicago to LA route 66 trip. I am sad I didnt see you. I suppose any advice now is moot.
Probably correct Bud....later car. 0 to 60 in 1/2 a minute
@GumballF355 I did end up getting a 420R from Rich but have since moved from SJ to Houston lol. I do miss the Bay Area quite a bit but life takes you places.
Unless it's been modified/upgraded it should be a single Stromberg carb in a 1500 Spitfire. All my former British sports cars had SU's, but I think the Stromberg's were used because they were easier to pass emissions. As well as your normal ignition/fuel supply checks, maybe take the dashpot off and check that the rubber diaphragm isn't damaged.
GumballF355 started following NorCal / Bay Area 7/7 Fish and Chips Run and 7 Owners in the Bay Area / San Jose?
Did you end up getting one? Theres a few around the South San Jose area. Im at the end of Almaden and building an MK Sportscars kit. Any chance the one you saw was a green caterham? I’ve seen it around sparingly too and I know a few other local guys who own them.
GumballF355 joined the community
2025 is shown on the title. SB100 is your friend in CA.
metaburnusa joined the community
Has it ever been clarified which manufacturer (model/year/part number) the steering rack is from?
8x13 not 15 and not by design...What is a Birkinized Caterham?
SU carbs.... not overly hard to tune but prone to leaking (seems to be a Brit car design function in that period)...any gunk will really mess them up. Use good filters not those goofy stock steel mesh ones that can only keep small birds from entering the throats....
jmaz started following The Other Cars of USA7s Members (Non-Se7ens only)
Your Spitfire's got a carburetor, not fuel injection, right? I'm trying to remember all the things that would go off on my former carbureted cars - TR4 and BMW 2002. Clogged jets and fuel filters weren't unusual. You note that the car had been sitting for a few years. Had the old gas been drained? The other common failure source was burnt or out-of-gap ignition points. Thing about the old technology is it was usually possible to get the cars to run, even if poorly. My newer (former) fun cars (Alfa Spider and Ferrari 328) were more of the "either runs or doesn't" mode. I'm hoping that my Caterham will be more predictable and easier to diagnose/fix.
Wow. Great stuff. Very interesting about the navigation.
- 1 reply
- 1
TSnuggs42069 changed their profile photo
TSnuggs42069 started following 2025 MK Sportscars RX5 250 and MK Sportscars RX5 Vtec K24
That looks amazing. I have been looking for something prettier and more civilized than my Exocet. We have considered a K20A swap for that car... Also looking at Caterhams but the prices are wild. We know our way around Miatas so I might have to try one of these out.
Nice looking car. I am curious about the NHTSA VIN. Does the car show up as a 2025 MK Sportscars RX5 250 or as a 1960 Lotus or something like that? California things...
TSnuggs42069 joined the community
7Westfield started following Intake manifold xflow
I've got an intake for an early xflow, the one everybody calls the Cortina engine Not as much flow as the later "uprated" model this is for the older engines with the combustion chamber in the head it has had some race prep done on it -port matching FREE to a good home, just cover shipping
(Attn admin: I'm not sure where this should be posted, it's an international event not National, so feel free to relocate, Thanks!) Just returned from the incredible 22nd Taffia Fish and Chip Run in Wales. I’ve been trying for several years (entries are capped at 300 cars, it was fully booked in 2 hours) and finally made the cut this year. The Caterham and Lotus Seven Club and the Taffia F&C Run organizers did an incredible job in hosting what has to be the premier Seven motoring event of the year. Starting with a BBQ on Friday evening (camping alongside your Seven for the hardiest of souls), Saturday morning breakfast (BAP), and run (some 263 cars made the start) from the Hanley Farm Shop (Chepstow) 140 miles north to Aberdyfi and Walkers Fish and Chips on the Irish Sea coast. The Sunday return to Chepstow on your own allowed for alternative routings to take in Mt. Snowdon, the Mach Loop, and the Bannau Brycheiniog National Park. It was UK touring at its finest, the beautiful countryside and greenery with never ending winding roads, lakes, rivers and seacoast, the essence of British sports car motoring, and in a proper British car, the Seven. I think several USA7s members have made previous Taffia F&C Runs, and I highly recommend it for any Seven owners must do list. I see Vovchandr has just posted a link to a Youtube video of this years run and Caterham Cars will be coming out with a 2026 Taffia Fish and Chip Run video likely similar to their excellent 2025 Youtube video. Thanks to Hannah at Williams Automobiles in Chipping Sodbury near Bristol (highly recommended), we were able to hire a 2015 360SV for the three days. The well broken in (42,000+ miles) Seven ran like a top never missing a beat. Thanks to Caterham Cars who sponsored in part this year’s run as well brought along a CSR Twenty edition and a 310 Encore edition. Finally, many thanks go to Jon Symons and the rest of the 2026 organizing committee and Derek Holliday for doing everything they could to assist us and personally making our F&C Run a success. A few take aways: The supplied mapping / routing and suggested MyRoute-app worked (short term free trial) extremely well with the proper level of map display and text, for the secondary roads of Wales; Google maps less so; and Beeline worked but is really more suited for motorcycles. But there is nothing like a hard copy “Road Book” and a suitable copilot / navigator. The organizing committee put together an incredible Road Book w/ the proper level of detail and notation to help with the many nuances of the roads / routings in Wales, something I haven’t seen in many years. A Club WhatsApp Community was set up for drivers / participants which provided a mechanism for rapid communications for everything from road conditions, detours, construction, weather, assistance needed, status, picture posting etc. which worked very well. Headsets w/ intercom are nice for pilot / co-pilot communications, but not necessary (we used a half hood and side doors / windows, and the rain / wind noise was not bad at all). Finally proper layering and wet weather gear are essential. We left 90 degs and sunny in Austin to arrive in London / Wales with 40’s-50’s maybe low 60’s and rain nearly everyday. This is one time we appreciated the endless heat emanating from the footwells in a Seven. Be on the lookout for notices about next year’s event about Mid-January 2027. Cheers! Steve and Akiko
- 1 reply
- 7
Week Beginning May 25, 2026 USA7s Classified Ads of Cars for Sale USA7s classified pages - USA7s club members have the benefit of selling their cars by listing them for free on USA7s forum. https://usa7s.net/ips/forum/26-cars-for-sale/ New Ads This Week Lotus 7 https://bringatrailer.com/listing/1966-lotus-super-seven/ Locost https://www.facebook.com/share/1Fhzg3nasL/ Locost https://www.facebook.com/share/1HTeQSHMKM/ Locost Project https://www.facebook.com/share/1aG5Nfu1zp/ Repeat Ads From Prior Weeks Lotus 7 https://www.hemmings.com/classifieds/listing/1963-lotus-super-seven-cochranville-pa-2891143 Caterham https://www.hemmings.com/listing/1999-caterham-all-models-526915 Caterham https://www.hemmings.com/classifieds/dealer/caterham/super-seven/2638345.html Caterham https://www.hemmings.com/classifieds/listing/2026-caterham-seven-miami-fl-2916813 and here https://www.facebook.com/share/1EAJEkDagy/ Caterham (with all the varying prices just pick the cheapest) https://www.hemmings.com/classifieds/listing/1998-caterham-super-seven-fort-lauderdale-fl-2914012 and here https://ebay.us/m/2R2wlX and here https://ebay.us/m/SMLyMd and here https://www.facebook.com/share/1AXjhLATUQ/ Caterham https://www.beachmanracing.com/inventory Caterham https://rockymountaincaterham.com/inventory/ Caterham https://rockymountaincaterham.com/csrtwenty02/ Caterham https://rockymountaincaterham.com/76907-2/ Lotus 7 S3 https://rockymountaincaterham.com/sb2352/ Caterham https://seattle.craigslist.org/see/cto/d/powell-butte-caterham-620r-lotus-super/7935566188.html Lotus 7 https://www.facebook.com/share/1Cc5j4pvti/ Stalker https://www.facebook.com/share/14exgf32PTh/ Locost https://www.facebook.com/share/1J6K2dShqi/ Locost Project https://www.facebook.com/share/1B4BP6dQvZ/ Locost Project https://www.facebook.com/share/18sFGTJh5B/ Stalker https://www.facebook.com/share/1EEDMe9P6i/ Caterham https://www.facebook.com/share/1CfGYFDLFU/ Caterham https://www.facebook.com/share/18aCEbrxjP/ Locost Project https://www.facebook.com/share/1D4HivRnuL/ Locost Project https://www.facebook.com/share/1GfrZgT9sA/ Caterham https://www.facebook.com/share/1BKSRmK36V/ Lotus 7 S2 https://www.facebook.com/share/1LsWgiNxHq/ Locost https://www.facebook.com/share/1CxxvCeZvS/ Caterham https://www.facebook.com/share/1937mUJP4A/ Locost Project https://www.facebook.com/share/1Bc3rqPhkK/ Locost https://www.facebook.com/share/18xQMcZTfL/ Diva https://www.facebook.com/share/1RiDwjBjV9/ Westfield Pre Lit https://www.facebook.com/share/1Zs9enm538/ Locost https://www.facebook.com/share/17VwscXNKB/ Locost https://www.facebook.com/share/1BLczqL1Qp/ Caterham SP300R https://www.facebook.com/share/1Go1mHtizW/ Caterham https://www.facebook.com/share/1BYo79UNAR/ Canada Ads Westfield https://www.autotrader.ca/offers/lotus-unspecified-westfield-seven-gasoline-green-47b3e30f-5dd5-4722-9b91-7f3938fd58f4 and here https://www.kijiji.ca/v-classic-cars/delta-surrey-langley/lotus-westfield-seven/1737752047 and here https://www.facebook.com/share/1HD1efdUwo/ Locost Project https://www.autotrader.ca/offers/bmw-2002-kit-car-9b5e3f67-7e4f-4f56-acac-2df6e6c12e99 Westfield https://www.facebook.com/share/18VUxNYgG8/ Caterham https://www.facebook.com/share/1B5xct6QRD/ -
I'm still planning to use four of the 8 x 15 wheels I have on my Birkinized Caterham. Doesn't sound improper to me.
Try just making a route with route7 and (I assume on your phone) click "Navigate full route". That sends the first 10 waypoints directly to Maps, just a big 10-point URL. Maps will automatically route turn-by-turn to the first waypoint, and when you get there it starts to the next. I did it yesterday with Android Auto, it was surprisingly easy. Exporting GPX & importing to Beeline is like 13 clicks total. Also very easy, but not quite as easy as the one-click Maps kickoff.
Software: the perfect routing/mapping app for group rides?
demoray replied to Austin David's topic in General Fabrication
I'm looking to have the beeline like experience on my watch. Maps has an arrow mode, which I've used, but I've not had good success importing GPX files with Google Maps in the past.
