THIS is not your typical Seven. The range-topper for over a decade, this specification commemorates 50 years of the Lotus/Caterham lineage (1957–2007). Finished in Ballistic Orange with black accents, this British icon is powered by the bespoke dry-sump Cosworth 2.3L Ford engine producing 260 hp, breathing through roller-barrel throttle bodies and a Westermann carbon ram-air intake. Power is delivered through Caterham’s own close-ratio 6-speed manual gearbox housed in a lightweight aluminum casing, paired with a 3.62 limited-slip differential. At just 1,395 lbs, performance is immediate and intense. The CSR 260 represents the most advanced evolution of the venerable Caterham platform, built around the upgraded CSR chassis—25% stiffer than standard—paired with fully independent double-wishbone rear suspension and pushrod inboard front suspension. The result is a Seven with markedly improved composure, grip, and stability, yet this upgraded version sacrifices none of the raw, analog driving experience. Legally registered in California in 2014 as an SPCNS with a 1957 Lotus designation, the car is permanently smog-exempt and retains its SB100 certification plaque in the engine bay. The car has current DMV tags and a clean title. Owned by the seller for 12 years, and with 7,300 miles on one of the last custom Cosworth crate engines to leave the line, the car presents in excellent condition following a mechanical refresh by Kampena Motors and a subsequent professional repaint in 2025. In December 2015, with chassis mileage at 4,985, the seller replaced the original engine with a brand-new Cosworth CSR260 crate engine of the same specification, as the original motor had several technical issues, incomplete service history, and had spent its life at 6,800 ft above sea level. The chassis has 12,200 miles since new, while the replacement engine has 7,300 miles and runs beautifully. The car has spent approximately two-thirds of its life canyon carving, blatting, and cruising, with the remaining third used on track. Key Highlights: • CSR chassis • Independent rear suspension (double-wishbone) • Pushrod inboard front suspension • Cosworth 2.3L dry-sump engine (260 hp) • Roller-barrel throttle bodies • Caterham close-ratio 6-speed manual gearbox (aluminum casing) • 3.62 limited-slip differential • Superlight roll cage, built-in fire suppression system, cutoff switch • Lowered floors, reinforced driver’s side, Tillet carbon/Kevlar seat, MOMO quick-release wheel, color-coded tonneau cover • AP brakes, uprated suspension, quick-ratio steering rack, dash-mounted shift-light sequencer • 15-inch alloys with new Toyo R888R tires all around Upgrades & Supporting Mods: • Westermann Motorsport carbon ram-air intake • Secondary oil cooler to better sustain track use • Reinforced rear diff mount/strut tower • Lightweight battery, reduced-drag lighting • New carbon rear protection panels Recent Service (2025, minimal use since): • New front brakes (calipers, discs, pads) • New half shaft • Differential refresh • Fuel lines replaced • Full service and brake flush • New Toyo tires front and rear Included with Sale: • Original order documentation & MSO • Clean Carfax • Extensive maintenance records • Full set of unused wheel bearings front and rear • Cat-delete pipe (standard exhaust with catalytic converter included) • Additional unused harnesses Not Equipped With: • Spare Tillet seat • Heater • Carpets (except transmission tunnel) One of the last Cosworth-powered CSRs, and arguably the most capable and complete Seven ever built. Engineered with true motorsport intent, this is an unapologetic and unforgettable enthusiast car—equally exhilarating on a country-road blat as it is on track. Worth repeating, even for those in the know: a 260 hp Caterham IS the therapy! And this one is ready for its next chapter. $53,000obo
- 5
FWIW I'll give my initial review of the Gyraline G1, the little brother to the G2 ($200 plastic unit readable to nearest 0.1 degree vs $600 aluminum unit? readable to nearest 0.01 degree), with software on your i-phone, as discussed by Austin David. Gyraline has several on-line Youtube videos which have been very helpful. The biggest thing I've found is I can measure and tweak the suspension as many times as I want very quickly w/o having to schedule / visit an alignment shop and depend on their technicians. This is very handy when rebuilding / refreshing or tweaking your suspension etc. etc. I've had the unit for several months and used it to dial in the suspension on my 2006 Lotus Exige after a complete overhaul / rebuild front and rear w/ new: Delrin bushings, tie rod ends, ball joints, Penske DA shocks, wheel bearings, powder coated a-arms, etc. i.e. 6-months plus effort. I first used the rotors as the reference for the G1 and then followed up w/ the wheels as the reference. Consistency in measurement technique provides incredible repeatability which followed by road testing and the occasional "string" check even for fairly minor adjustments gave me a lot of confidence in the G1. Of course, it helps that everything on the suspension (and tires) is new so the car has a completely different feel (far more precise and responsive). Toe (individual relative to car CL and total front and back) and camber are easily dialed in as well rapid checking for bump steer. After getting the Exige to 90% of where I want, still working on bump steer w/ limited options for adjustment on the Lotus, I moved to my 2009 Caterham S3. I upgraded to Penske DA shocks and revised spring rates, checked all suspension bushings, rod ends, ball joints etc. As a precursor to replacement of all bushings (Powerflex), rod ends, tie rod ends and ball joints (using Jack Webb's (UK) incredible Caterham suspension bits for improved camber and bump steer) I checked, adjusted / tweaked the alignment w/ the G1. Again, incredible how fast I can measure and adjust everything, and feel immediate results on the road. I'll give further update(s) as I get into the S3 suspension overhaul / rebuild but the $200 spent on the G1 has been well worth it for me. Of course, as always "your results may vary". Cheers! Steve
Mine came in over the weekend. It's the "G2" which has some sort of internal hardware and runs an app on my phone. I've reached out for some support, hopefully will hear back during the week. I did a check of my wife's car, which has unknown alignment but I assume it's OK. The numbers weren't crazy, but I didn't save them. IIRC it was something like -0.25 toe front + rear, but very precise-looking values like -0.18* and -0.37* The app has a few modes including a 4-point and 6-point check, plus a thrust angle which uses a body reference. The body reference I chose was the sill where the scuttle hits the "door". I'll assume my car is still square, it's never touched anything. The rear is a dedeon with machined plates, so I further assume the toe is controlled very precisely, tho thrust angle could be off slightly. note that in the photos below the "+1.00*" is a configuration I added, it doesn't actually mean anything for the measurements. here's #1 and #2. The pictures look alarming but the actual values are small. Note that the car didn't move at all during these two measurements, I just repeated the same test twice. The procedure involves holding the phone+device flat (the diamond in the center is your level reference), then hold it against the reference point on the body or the wheel. One of those will blink saying which one it wants next, you align it then tap to confirm. It sends you back and forth a few times to get the measurements before showing the result. I do expect some toe in here, and I think it's underestimating twice. As this is a dedeon I don't feel like toe has much room to wear -- it's steel or aluminium all the way around. I also did the "6 point" check for toe front+back, twice: again, the car wasn't moved between tests. This time the rear toe is more consistent but the front varied a lot. I have not tried to independently measure in 15k miles but I expect the front to be toed in a little. I'd already reached out to the team to see if they could help with the square-check. I don't know if a good set of thrust values would really help here... maybe? My dedeon doesn't have any thrust angle adjustment, I think the two swingarms will constrain that angle. At best I could try and shim the assembly left or right but I don't think the gyraline (as currently provided) can account for that. And It was shimmed + measured when I built it... The above 6-point rear toe check is encouraging, but the fronts and the thrust angle seem ... variable. I'm not sure what the expected accuracy is. I assume something like 0.5 or 0.25 degrees, just based on the swing in the numbers below. But if that's the case I have a front that may or may not be neutral. Based on the very obvious inside wear on both tires after 17k miles I assume they're toed in just fine. I have not yet attempted camber measurement. Again with the dedeon I expect the rears to be very precisely constrained. The fronts were aligned when new and with no accidents and mostly grocery and road trips, I expect the fronts to be about -1.5*.
Its a big readjustment process but incredibly rewarding as a driver. Most people come from bigger cars which have enough weight over the nose to just hammer the wheel left or right and the car just goes. However, a Caterham (or Birkin or Westfield or Locost) just do not have the nose weight when under acceleration so a left or right turn in that state will just lead to scrub. A brief lift of throttle or light tap on brake is nearly always enough to put more weight on the nose/front wheels to get them to bite for your turn. Then you can play with throttle in the corner to adjust attitude. Think of it in a sequence. Corner coming up. Brake to get weight over nose. Once weight is on nose then off brake and turn in. Once turn iniitated then start to feed in power progressively to come out of corner quickly. Slow in and fast out. Ross Bentley in his Speed Secrets series has a good section on managing weight transfer around the 4 wheels for varying outcomes. Find his first book in the series and have a read. Then go out and experiment - great opportunity for a track day since you can do it safely plus repeat corners to adjust technique and get a good seat of pants feel. Also read his section on trail brake as this is a great technique for keeping the rear end controlled under late braking entry to corners - Caterhams respond well to trail braking. Its more lack of weight on front tires under acceleration. Its not a 50/50 weight distribution front to rear as a driver is a lot heavier than a 4 cylinder Ford engine. Obviously with the aerodynamics of a brick, there is some front end lift which exacerbates the problem. The example corner for me is Copse at Silverstone. Its the old turn 1 if you are using the old pits. Its 60 foot wide track going and about 80 foot wide coming out. I go in at redline in 4th and have 15 feet of available track on exit, even without braking or lifting. And I scrub understeer the whole way through. I do not need to tap or lift as the track is so wide. But I have to do a lift to set the front tires up for a quick corner. Frustrating. Luckily there are not many places where that is an issue - top corner just past the rising esses at VIR, Copse at Silverstone, two corners at Portimao, entry into corner 1 at double Gauche at Spa, etc. Caterham sell one for rear camber and toe: https://caterhamparts.co.uk/de-dion-tube/6531-camber-and-toe-shim-kit-de-dion-cars.html I would ping Josh at Rocky Mountain - I bet he has some in stock. You do need to know where you are starting from on rear alignment. How much rear camber is dialed in from the standard de Dion. Should be 2.5deg but that is not guaranteed - check will tell you. Borrowing a photo from someone else since I am flying this month and won't be near my cars until June. Front - back of wishbone. Photo shows a more recent model Caterham with ali skin. The ruler points at measuring point. My measurement was ground to chassis tube as not all cars are covered in ali there (e.g. older chassis and race cars) but you can deduct the right amount of ali skin cover from the 120mm. For the rear measurement point, do it ground to chassis tube at the rear axle point - no photo handy right now. Its not much - only +5mm rake front wheels to back wheels.
