coffee break
  1. Let's hope they are candidates for Jay Leno's "Stupid Criminals" award.
  2. OK guys, what are the two like bodied cars in Bob's last photo. I'm guessing they are from the 1950's and have 'Merican iron power, beyond that???
  3. pksurveyor, you give a whole new meaning to being "cat" people.
  4. It's not a 3 minute egg but I've been boiling parts. The radiator fan switch closes around 190F. The switch has four number groupings stamped on the flat surface. One of the numbers is 92, I would guess that is for 92C. I did a side by side test with the installed thermostat and the new out of the box 180F unit. The new part opened around 182F and the old one around 185F and did not open as much as the new unit. So, in with the new and figure out a manual override to be over cautious.
  5. For starters, pull the core out and measure L, W, H and make a sketch with the location and size of the connecting tubes. It can help when looking for generic applications of heater cores.
  6. The Pegasus set-up looks good. I will need to see if my car has a fan relay or if the switch directly controls the 15A fan circuit. Thanks Anker
  7. It can with a California title, if that helps.
  8. Is the heat insulation on the footwells and tunnel an option or a factory standard item. Good idea either way.
  9. I removed the existing thermostat and it is marked "180". I think I will install the new one of the same value. The fan switch is a puzzle, not much on the markings. The OD of the thread is .859" and the thread gauge that fits it best is 18 TPI. The threads are not tapered as pipe threads are. I'm thinking about adding an override switch I can use to turn on the fan if the elevated temps reoccur.
  10. Bob, Thanks for the pix. Do you have any more of the sideways VW bus? :smilielol5: Carl
  11. I confirmed the function of the fan switch. It closes around 190F. I picked up two new thermostats to replace the existing one. The suggested one is a 180F and the alternate is 160F. Any down sides to going with the lower temp part?
  12. John, Thank you for confirming the sanity* level required to be a 7er. Well done. Carl * or lack there of
  13. In the past the fan has keeped the coolant temp at 85c. I jumped the wires that go to the switch and the fan came on. I guess I'll boil the switch and see what the multimeter tells me.
  14. I could use some help identifying the radiator fan switch on my 1600 crossflow. Last time out the water temp was above what it should be. Coolant level was good. Suggested vendor? Thanks y'all
  15. I guess the Vett doesn't scratch the itch.
  16. +1 wtf! (I have tried to capitalize WTF in the edit mode with no success, odd)
  17. “Lotus 7 AmericaLotus 7948cc BMC A-Series That's a big ass motor.:smilielol5:
  18. Is there an auto parts store near to you that has an alt. tester? I don't remember if you said anything about that earlier.
  19. That's nice, on the other hand she had warts...
  20. Yes, people are drawn to shinny objects. It also depends on who you are looking to sell it to. Shinny and clean cars are better for the street, C&C, car shows and track cars not so much.
  21. Is that a "Big Hairy ???"
  22. xcarguy, there are some things I just don't want to know.
  23. I thought I heard an "aaaarrrrgggghhhh" today. Keep on posting photos of clean and shiny motor parts. :drool:
  24. Lookin' good
