coffee break
  1. John, Thanks for keeping the wheels turning. Carl (thumbs up)
  2. Two low profile nuts. Install and tighten the first nut. Install the second nut and tighten it against the first while keeping the first nut fixed with a second wrench. aka jamb nuts
  3. Several years ago, I took the opportunity to apply some reflective insulating material to the firewall and as far as I could get down the tranny tunnel. I also wrapped the exhaust header. I got the header wrap from Summit Racing, the insulation may have come from Pagasus. Needless to say, it was much easier to do with the engine and transmission out. It is highly recommended.
  4. Lookin' good. Let me know if I may be of assistance.
  5. A shake-down ride from New Hampshire to Portland OR in February, hmm I'd take a detour thru Key West. I hope the car check out is a GO!
  6. Hmm, the fan looks like ground effects.
  7. Lookin' good, it should sound good also. Thanks for sharing your progress.
  8. Looks like a SV, a close-up of the badge may help. Enjoy the journey.
  9. There has to be some kind of interesting store for a car this clean and running to be "salvaged". This isn't a diamond in the rough it's fully polished. Enjoy!
  10. There may be an electrical component that is draining the battery. A master power cut-off switch to isolate the battery would help with battery issues.
  11. DR Hasegawa it is always a treat to see your messages. Great photography as usual.
  12. Welcome to the mysteries of hand built cars that are pieced together from various parts bins. As Croc was pointing out loose wire connections especially grounds can be causing intermittent operation. 7s do a lot of vibrating and can loosen connections up, also wires pinched in tight places can also do it. Answer: "Dim, flicker and off" Question: "What are the three switch positions for Lucas lights?"
  13. Good stuff, a Triumph Spitfire as a tow vehicle.
  14. Hmm sounds like a bent rack.
  15. Only reason consider not driving a 7 is that you can't hoist you hinny out of it.
  16. Let's see, no paperwork, no VIN/chassis # listed, it could be dodgy. Has anyone done a 7 ratrod?
  17. Good looking views except the sign with gas prices. Thanks for posting.
  18. I'm wondering if or when Bring a Trailer will step in and pull the S2 auction. They may be in conversation with the seller, but that is not known publicly. It appears to be too dubious to pass the smell test.
  19. Hi Chris, Everyone was new here at one time. At to the oil leak, how would you describe the "puddle". Dime, quarter size, Exxon Valdese? In the classic British car way, they leak. Keep the fluid levels up to full (engine and transmission) until the leaks are address. Good luck.
  20. This is a questionable auction. There is no ID on the chassis, so there is no way to pass the "is it stolen or not" question.
  21. With the proliferation of 3D printers it may be possible someone has laser scanned the part and made some.
  22. Sounds like an "Offer you can't refuse"
  23. The documentation is as comprehensive as skill and detail put into this project. Looking at this is like drinking from a firehose, how long has this projected lasted so far? Well done!
  24. This is a good place to find current and past owner of crossflows.
  25. Is there a u-joint on the steering shaft that allows the rack to be rotated? If so, the u-joint may be binding. Could the rack be shimmed up to space the shaft upwards without adding too much bump steer?
