Everything posted by Croc
A return visit to Spa-Francorchamps in a Caterham - 2018
Croc replied to Croc's topic in General Sevens Discussion
Yes folks, if it is cold and you sneeze inside your helmet you do fog up your glasses – here I am waiting to de-fog so I can see. There are many people of alternative persuasions – even Westfield owners enjoy track days. They are quite patient at letting others overtake them… Sorry Westfield owners - I just had to troll JohnCh! -
Bookatrack track days are extremely well organized. High quality of driving. Strict enforcement of some basic rules that ensure predictability and safety on track. Plenty of interesting cars to check out. Very friendly crowd. If you want to drive the circuits of the UK or Europe, these are the guys to go with. Some pit scenes -
For this Spa treatment, I rented a Caterham 420R SV. 220hp Duratec. 5 speed gearbox, and LSD. Nice goodies of leather road seats, aero screen and regular track day roll bar. What I did not expect is that it was brand new. 5 miles on the odometer. Naturally it required a little fettling on the brakes, some more bleeding to make the pedal firmer to my liking but I was sensible about doing a thorough check myself before racing out there and being silly. As it turned out it was perfect. Not one issue during the two hard days on track. The only part of the spec I struggled with was the 5 speed gearbox. The ratios were all wrong. A similar engine car with the 6 speed gearbox gets away from you pretty smartly by just having 2 extra ratios – 6 speeds to your 4 speeds – as the 5th gear is overdrive and the 4th gear is direct, matching the 6th gear in the 6 speed box. So along the Kemmel straight I felt like I was doing a high speed economy run in 5th gear as it just would not pull any further, even after changing at the redline in 4th. There is good reason the 5 speed box was specified. Apparently there have been quality issues with the 6 speed box. Given the life these track cars get then you want them reliable. So I needed to get out there and do my public service by running in that Duratec nice and carefully….errr.... right…. I can just see the for sale ad later – Company demonstrator model, run in carefully by little old lady on Sunday drives in scenic Belgian mountains…. -
The exit (corner 11 exit) Double Gauche is seriously quick and incredibly satisfying if you get it right. Somewhat early looking entry, mild brake tap in 4th gear, hold the wheel and let the car arc out to the right before arcing back to the second apex. If you get it right then you just hold the wheel constant through the corner and feed the power in. Just after the first apex I am foot to the floor through the rest of the corner. You are carrying some serious speed by the second apex and for me getting up towards the redline in 4th gear. Get it wrong and it is one hell of a wild ride. Plenty of tarmac run off once you get beyond the artificial grass. Then on to Fagnes (corners 12 and 13). This is corner 13 below. It is slightly uphill and favorably cambered. So you can carry good speed right through corner 12 and then flick the car back left for corner 13 all while feeding the power in and generating just a slight drift from the tail – epic fun. Then it’s on through Campus and onto the straight than leads into Blanchimont. An open left double sweeper – no lifting – before you arrive at the Bus Stop And here So it is a hard braking down from around 120-125mph (in a 420R) to like 30mph, flicking right then left. And at this point you are back at the modern pit straight accelerating up towards La Source. -
Then its to the downhill lefthander (corner 9 on the map). This is tricky to judge. It’s tighter than it looks. It has two green plastic posts on the apex so don’t cut this corner. There is not much run off and if you do get it wrong on exit there is artificial grass just after the curb, not very nice for grip as the car goes all squirrely there. And just to ensure there is a high level of pucker factor, as you track out from the apex there is a dimple in the circuit, right where your right rear wheel tracks out. So you have to watch for the rear end snapping away from you at just the wrong moment. Then onwards, faster, downhill…. …..to the Double Gauche (corners 10 and 11 on the map). Some people call this double apex left sweeper, Pouhan corner. The entry (corner 10) The middle (corner 10 exit and corner 11 entry). The skid marks tell the story of what not to do with the corner... -
Raidillon is the top of the hill. When you come through Eau Rouge (no lifting…), you cannot see the next corner so you aim the car using the tops of the pine trees and if all goes well you pop across the top of the crest, two left wheels on the Raidillon curb as you then track out right. Then you are on the long Kemmel straight. Its essential to get a high speed run through Eau Rouge and Raidillon to max your speed on the straight. You are still gaining elevation here, heading towards the highest part of the circuit at Les Combes. This is the exit of Les Combes (corner 7 on the map) and the highest elevation of the circuit Some mention has to be made of the elevation change on this circuit – its massive. The lowest point on the circuit, just after Campus corner is at 1110 feet of elevation (from sea level). The highest point on the circuit is just exiting Les Combes at 1410 feet of elevation. So in 1.5 miles the circuit drops 300 feet. Alternatively, consider that at La Source corner the elevation from sea level is 1272 feet. At Eau Rouge you are at around 1140 feet and at Raidillon you are at 1242 feet of elevation. So in track distance of about an 6/10ths of a mile you have descended 132 feet and then in the next 300-400 feet you ascend 113 feet in elevation. Pretty radical elevation changes that are only equaled in circuits like Mt Panorama in Australia or Portimao in Portugal or the Nürburgring. So after Les Combes it is downhill into the right handed sweeper Bruxelles (corner 8 on the map). This is off camber initially although it starts to ease off as you get through to the last third or quarter of the corner. Looking back uphill to the exit from Bruxelles -
The Saturday was a test day at Spa, so I drove into the pits, dropped the car and proceeded to walk the circuit in its entirety Despite having been there before, I had never walked the circuit. This helps you understand the geometry and layout of a corner, whether there is elevation change, camber change or other little nuggets of information that can help you drive the circuit quicker. This is a fast circuit – I average 85mph – that’s an average! Astounding when you think about how a Caterham does not have a particularly high top speed. So the game is to carry as much speed as you can through every corner. The following photo is looking uphill at the old pits and back towards La Source (corner 1). Then standing in the same spot but swiveling left is Eau Rouge (at the base of the hill – corner 2) looking towards the top of the hill where Raidillon corner is located. Moving up the hill to the top where Raidillon is located but looking left a little, you get the classic Spa-Francorchamps view back down the hill to Eau Rouge, the old pits and La Source in the background. -
Following this I drove the old circuit. Originally the circuit was laid out on the local public roads. Eventually this became too dangerous and the modern day circuit, still based on local roads, was carved out and enclosed. Up to 1970 Formula 1 and GT races were being held on public roads, running through villages, alongside houses, fields, with no safety barriers or run off. Speeds averaged 180mph along these roads. For example, this is the old Malmedy straight. And here is part of the Masta kink. If you know where you are looking there are some gravestones along these roads, in drainage ditches by the side of the road, or next to old trees, memorials to the racing drivers who died in high speed crashes. Quite sobering. -
A diorama of the circuit – old and current – in the context of the surrounding area -
Given I arrived on the Friday and was not driving until Sunday, I decided to take a few scenic drives around the old circuit and visit Stavelot where the Spa-Francorchamps museum is located. The Museum is located in the undercroft of the restored Abbey. Its not big but the displays rotate regularly and everything is very interesting and well done from original race cars, memorabilia and old photos. -
I do a write up for all my track trips for my photo albums so I am sharing my notes from that. Yellowss7 knows all about my Shutterfly photo albums! I figure everyone enjoys a good Sunday morning browse with a cup of coffee. So in late March I just happened to find myself in Belgium for a weekend at Spa-Francorchamps, in the Ardennes, about 1.5 hours east of Brussels. I was last there in July 2013 and had promised I would return but as usual work, life, other cars, family, blah blah, get in the way. It is simply one of the best 3 tracks in the world to drive and a seven is just so well suited around there given the momentum style of driving. Ignoring that, I signed up for the 25th and 26th (Sunday and Monday) with Bookatrack and again rented a Caterham with them. I believe they run the best track days of any operator anywhere and they are such a fun group of people to be around. https://www.bookatrack.com March is an uneasy time for a track day at Spa as you never know what could happen as I learned in March 2013 and got the distinct pleasure….err….experience of driving on track in snow. Not recommended, even at Spa. As it turned out I need not have bothered – sunny, clear, some clouds and in the 50s both days – just perfect. To remove any chance of jet lag, I flew in early to Brussels and meandered my way over to Spa town, an easy 12 minutes drive from the track. This was a change from staying at a hotel next to the track as it allowed for enjoying the town’s various nice restaurants in the evening and a nice walk around what is a pretty little town nestled in the valley.
There are a few issues with the 2040-cars.com website, namely: (a) Sold cars are never removed (b) every so often you find cars sevens which are not actually for sale i.e. they are owned by a person I know who is not selling. There are 3 listed on the sevens page now. Scam sale or just a way to drum up some interest? © the prices for listings can be ridiculously out of line with markets which gives you the "is this genuine" suspicion. (d) the rest of the website has not been updated since 2014. Some people may have had success with it but I found it too sketchy for my liking. -
Congratulations on your purchase. You bought through the Vintage Race Car Sales - Kim Baker. I saw the ad surface and it caught my eye for a bunch of reasons - turbo, polished ali, metal front and rear wings, etc. Its a striking looking car. Looks like you will need to let the snow melt before you really try out the driving experience!
Great idea Duane as I am not familiar with that website. NEW This ad is for a car in Switzerland based on a Caterham CSR. You would not be able to import this to the US but it is a striking rethink of a seven. Not sure about the grille.... https://www.ebay.com/itm/Lotus-Super-Seven/162963063996?hash=item25f15b04bc:g:Q20AAOSwHG9atqYX&vxp=mtr Lotus 7 S2 https://www.hemmings.com/classifieds/cars-for-sale/lotus/super-seven/2088739.html#&gid=1&pid=3 Westfield 15 http://www.wirewheel.com/1959-Lotus-15-Replica-for-sale.html Dutton 7 https://sandiego.craigslist.org/nsd/cto/d/lotus-7-dutton/6547756869.html REPEATS Stalker https://www.ebay.com/itm/1962-Lotus-Stalker-Super-7/282889447865?hash=item41dd8669b9:g:ELkAAOSwPGpaiKDT&vxp=mtr Lotus 7 S4 https://www.ebay.com/itm/1974-Lotus-Seven-S4/272993367211?hash=item3f8fac34ab:g:rsIAAOSwL81aPVwg&vxp=mtr and here https://www.hemmings.com/classifieds/dealer/lotus/s4/2049263.html Caterham http://britauto.com/portfolio-view/201216-nos-caterham-sv-roadsport/ Lotus 7 S2 https://www.hemmings.com/classifieds/dealer/lotus/super-seven/1871753.html Westfield https://www.hemmings.com/classifieds/dealer/lotus/westfield/2043172.html Caterham https://www.hemmings.com/classifieds/dealer/lotus/caterham/2084168.html Caterham Sp/300R https://www.hemmings.com/classifieds/dealer/caterham/unspecified/1818419.html Caterham http://www.wirewheel.com/2014-Caterham-Seven-for-sale.html and here https://www.hemmings.com/classifieds/dealer/caterham/super-7/2081484.html Westfield https://classiccars.com/listings/view/992785/1965-lotus-seven-for-sale-in-washington-missouri-63090 Lotus 7 S1 https://classiccars.com/listings/view/1065332/1958-lotus-seven-for-sale-in-stratford-connecticut-06615 Caterham SV Hayabusa http://www.race-cars.com/carsales/other/1458694360/1458694360ss.htm Stalker M Spec https://washingtondc.craigslist.org/nva/cto/d/brunton-stalker-spec-001/6546281595.html Stalker V8 https://denver.craigslist.org/cto/d/road-race-car-lotus-super/6537924782.html Westfield https://lasvegas.craigslist.org/ctd/d/1965-lotus-seven-westfield/6528981199.html Replica V8 Project https://seattle.craigslist.org/tac/cto/d/street-legal-hot-rod-track-car/6525729627.html Replica https://erie.craigslist.org/cto/d/lotus-super-7/6506798371.html Westfield V8 https://newyork.craigslist.org/wch/cto/d/1968-lotus-super-seven-8/6532887107.html Champion Stage 2 roller https://miami.craigslist.org/mdc/cto/d/lotus-super-seven-replica/6517980129.html -
fitting new 13'x10' 3 piece wheels, clearance issue?
Croc replied to CamT's topic in Wheels and Tires
Thats a name in wheels I have not heard of in a while - good to hear they are still around. The only person with 13x10 wheels on a Caterham that I know of is Yellowss7. Ping him with a PM if he does not react in the next 24 hours. Not sure why you would want that wide but I guess cold weather autocrossing? -
Registration, Emissions Testing and OBD
Croc replied to ukchris's topic in General Sevens Discussion
I am not sure discussing title washing on a public forum is a great idea...for the record it is a legal no no. For my 2004 yellow SVT zetec, it used the Ford ECU that had OBDII and had the standard intake. It used to throw error codes - transmission, evap, and fuel tank - three things different on a Caterham compared with a Ford Focus. I am not sure what specific Ford model ECU it was but it came out of a Ford Focus - easy enough to work backwards. -
Welcome! 6'4" is easy. Blubarisax on this forum is 6'8" and we got him into an SV. Secret was lowered floors and a "taller" roll bar. Also going to a bead resin custom seat gave another inch headroom over the standard leather or tillet seats.
Since when did NH, the land of the free, go with mandatory OBDII? Paul - how did you get your Birkin on the road when you were living there? -
This is one time you don't want to use the website. Give them a call. They both know what a Caterham is but websites do not even begin to understand the complexity of premium rate tables that are approved for use by that insurer. A conversation with all the facts should 80% of the time get you a better price quote than a website with the same company.
Forget GEICO - they are just giving you the basic state minimum insurance pack - no protection for your car or any personal liability. They will depreciate the insured value over time. You want agreed value insurance - so Hagerty, AMIG, Grundy, etc. Check the fine print - insurance needs to cover the value of the car if it is stolen, written off or otherwise lost. You need to make sure the liability limit is at least equal to whatever personal excess liability cover kicks in at. The exclusions should be minimal. You need to re-quote AMIG as they have not quoted you comprehensive agreed value insurance. Hagerty's price surprises me especially in NH - I would double check that. You should ask who the insurance company is that is issuing the policy. Hagerty (like Grundy) is a managing general agent - not an insurance company. So they rely on insurance companies to support their ability to sell policies. Also try American Collectors https://americancollectors.com/ Insurance is just a legal form of gambling. The price quotes reflect which insurance company got hit with a lot of losses recently on a collector car market in New Hampshire.
Thats the understatement of the week! :rofl: -
Pets can be dangerous. :rofl: I think this is the upper steering column you want https://caterhamparts.co.uk/columns/127-quick-release-steering-boss-and-column.html?search_query=steering+column&results=83 Your existing wheel may just bolt on - you may need a new steering wheel and column connector though. I suggest you wait until your car arrives then once you have a visual on the car, give Caterham Parts in the UK a call, talk through what you want to do and they will help you order what you need. They will send it pretty quick. The other US dealer with spares is Bruce Beachman in PNW. No website - just call him. I like the old fashioned approach. This is the Caterham solution. You can still pull out your upper steering column and attach the adapter like Shane did above. All the bits are here to achieve the result Caterham did.
Quick update today since I am getting a comprehensive spa* treatment this weekend - Some no lifting through Eau Rouge, an opposite lock through La Source and a high speed turn through Blanchimont in a nice new Caterham 420R will make me as good as new with no wrinkles or bags under the eyes. May need new underwear though given the temperatures the 30s and cold tires.... NEW Caterham Roadsport SV (Skip should know the collection of cars this one is being sold from - the background photo shots are impressive) https://www.ebay.com/itm/2011-CATERHAM-SERIES-5-SUPER-7/202266094343?hash=item2f17ffab07:g:XC0AAOSwqlFar-6k&vxp=mtr REPEATS Caterham SV http://britauto.com/portfolio-view/201216-nos-caterham-sv-roadsport/ Stalker https://www.ebay.com/itm/1962-Lotus-Stalker-Super-7/282889447865?hash=item41dd8669b9:g:ELkAAOSwPGpaiKDT&vxp=mtr Stalker http://www.usa7s.net/vb/attachment.php?attachmentid=13942&stc=1 https://www.ebay.com/itm/1962-Replica-Kit-Makes/152953033004?hash=item239cb6112c:g:G~MAAOSwacVasb06&vxp=mtr and here https://denver.craigslist.org/cto/d/road-race-car-lotus-super/6537924782.html Lotus 7 S4 https://www.ebay.com/itm/1974-Lotus-Seven-S4/272993367211?hash=item3f8fac34ab:g:rsIAAOSwL81aPVwg&vxp=mtr V8 Replica project https://seattle.craigslist.org/tac/cto/d/street-legal-hot-rod-track-car/6525729627.html Westfield https://lasvegas.craigslist.org/ctd/d/1965-lotus-seven-westfield/6528981199.html Replica https://lexington.craigslist.org/cto/d/lotus7/6513158390.html Replica https://erie.craigslist.org/cto/d/lotus-super-7/6506798371.html Champion replica roller kit https://atlanta.craigslist.org/atl/cto/d/lotus-super-seven-replica/6517988864.html Westfield V8 https://newyork.craigslist.org/wch/cto/d/1968-lotus-super-seven-8/6532887107.html OTHER BDA Engine - coming out of a Caterham by the looks of it https://www.ebay.com/itm/Cosworth-Ford-Caterham-Lotus-Twin-Cam-BDA-Engine-Dry-Sump-Weber-Carburetors/232682633033?hash=item362cf73749:g:GV8AAOSwcedal2ak&vxp=mtr * Spa-Francorchamps Circuit in Belgium
