Squeegee Posted June 21, 2020 Share Posted June 21, 2020 First week of a few hours per day in the books. Wishbones, steering rack, dampers and uprights installed on the front end. The first step was the toughest, getting those four washers in the lower wishbone where there is really only room for three. I ended up inserting the three and holding them in place with a screwdriver while I pounded in, I mean "gently inserted" the fourth. To get the holes to line up I should have used a tapered punch, but I didn't have one. Instead I used the leading edge of drill bits for their taper. I tapped one in, and then moved on to the next larger to get the washers all lined up for the bolt. Not what the folks who made the drill bits had in mind when they made them, but it got the job done. BTW, there are some pretty tight quarters in there. Any suggestions for a small, swivel head torque wrench? The torque wrench I have now is of a size and an age that I think it might have been used to bolt together the Titanic. Link to comment Share on other sites More sharing options...
Pokey Posted June 22, 2020 Share Posted June 22, 2020 Can't suggest a flex head as I don't have one, but if you are struggling with space you could get a set of torque adapters or use your wrenches with: https://www.revzilla.com/motorcycle/motion-pro-adjustable-torque-wrench-adapter. Link to comment Share on other sites More sharing options...
JohnCh Posted June 22, 2020 Share Posted June 22, 2020 This might be too big at a touch under 18" long but I love mine. They also do a 10-50 ft lb version, but I believe it's the same length. Precision Instruments Split Beam -John Link to comment Share on other sites More sharing options...
Brightonuk Posted June 22, 2020 Share Posted June 22, 2020 Gonna enjoy watching this build Link to comment Share on other sites More sharing options...
coffee break Posted June 22, 2020 Share Posted June 22, 2020 Is the heat insulation on the footwells and tunnel an option or a factory standard item. Good idea either way. Link to comment Share on other sites More sharing options...
sf4018 Posted June 22, 2020 Share Posted June 22, 2020 Congratulations and best of luck squeegee! :auto: Link to comment Share on other sites More sharing options...
11Budlite Posted June 22, 2020 Share Posted June 22, 2020 Is the heat insulation on the footwells and tunnel an option or a factory standard item. Good idea either way. I believe it comes standard now. It's installed on mine too. Link to comment Share on other sites More sharing options...
Squeegee Posted June 22, 2020 Author Share Posted June 22, 2020 Thanks for the torque wrench advice. Another update next week. Link to comment Share on other sites More sharing options...
Squeegee Posted July 4, 2020 Author Share Posted July 4, 2020 Update: I have the headlights, front brake lines, horn, air box and heater installed. I had some trouble with the front anti-roll bar. Josh from Rocky Mountain Caterham is sending me a replacement for the end ball I trashed. Totally my fault. I didn't clean out the excess powder coat from the sockets. I have plenty of time for for Dremeling while await the replacement. I guess I could install the radiator, but I don't want anything fragile nearby while I'm trying to hoss the ARB into position. This the part of the process that my wife refers to as "Crammin', Jammin', and Damnin'." Link to comment Share on other sites More sharing options...
panamericano Posted July 4, 2020 Share Posted July 4, 2020 "Crammin', Jammin', and Damnin'." - Love that. Tell your sainted wife she is good. "heater" ? My you Caterham lot are softies. Link to comment Share on other sites More sharing options...
SENC Posted July 5, 2020 Share Posted July 5, 2020 "heater" ? My you Caterham lot are softies. :smilielol5: what next, a fuel gauge? Link to comment Share on other sites More sharing options...
Squeegee Posted July 11, 2020 Author Share Posted July 11, 2020 It took a little head scratching, but it finally occurred to me that, in order to get the "push-pull" of the heater cable to work properly, all I had to do was install the Heater Control Valve (HCV) upside down (and remember to reverse the hoses when I get to that part of the plumbing). I also have the ARB and the radiator installed). Link to comment Share on other sites More sharing options...
Squeegee Posted July 25, 2020 Author Share Posted July 25, 2020 The Engine is IN ! I was little confused about a connector coming off the engine that didn't seem fit the connector it lined up with. Josh at Rocky Mountain Caterham figured it out for me. The receptor I had found was a "vestigial connection" left over from when they used K engines, so it can be taped off and ignored. The green connector coming off the engine goes to the MAP sensor, which Caterham had failed to attach to the chassis or include in the parts. It's on its way from Jolly Olde, so you can all look forward to questions about exactly how I attach that to the chassis and where the hose enters the intake manifold in a couple weeks. Link to comment Share on other sites More sharing options...
Croc Posted July 25, 2020 Share Posted July 25, 2020 The Sigma really does neatly package in a Caterham. I laughed at your heater deliberations - brings back memories of not being able to reinstall mine years ago. Gave up, was enjoying a beer when the lightbulb went off on how to install it. Link to comment Share on other sites More sharing options...
sainthoo Posted February 21, 2022 Share Posted February 21, 2022 On 7/11/2020 at 3:44 PM, Squeegee said: It took a little head scratching, but it finally occurred to me that, in order to get the "push-pull" of the heater cable to work properly, all I had to do was install the Heater Control Valve (HCV) upside down (and remember to reverse the hoses when I get to that part of the plumbing). I also have the ARB and the radiator installed). How did you route your cable? Maybe I have the wrong one, but it is way to long to keep it on the same side. I have been stumped by this too. my cable: o Link to comment Share on other sites More sharing options...
Squeegee Posted February 21, 2022 Author Share Posted February 21, 2022 Here is the routing I used for the heater cable. It appears mine goes through the firewall at a different point than yours. I did have to shorten the cable. If i recall correctly, I used a tubing cutter on the outer layer and simple wire cutters on inner. Good luck! BTW, I love yoir paint scheme. Link to comment Share on other sites More sharing options...
sainthoo Posted February 21, 2022 Share Posted February 21, 2022 Thank you! I was terrified to cut anything. Waiting for word from either Caterham directly or Josh at Rocky Mountain Caterham before doing anything. Link to comment Share on other sites More sharing options...
Squeegee Posted February 22, 2022 Author Share Posted February 22, 2022 Josh has been a great and supportive resource for me. You can't go wrong with any advice he gives you. Link to comment Share on other sites More sharing options...
