KnifeySpoony Posted Monday at 09:12 PM Posted Monday at 09:12 PM Tell me about the sizes on the R7s and slicks
sf4018 Posted Tuesday at 03:21 PM Posted Tuesday at 03:21 PM 18 hours ago, KnifeySpoony said: Tell me about the sizes on the R7s and slicks Type Manufacturer Model Comp. Front Wheel Size Front Part # Rear Wheel Size Rear Part Number DOT Avon ZZR A64 13x6 185/55R13 13x8 215/55R13 ZZR DOT Hoosier R7 R7 13x6 P185/60ZR13 13x8 P225/45ZR13 Slick Hoosier F2000 R35B 13x6 20.5x7.0R13 13x8 22.5x8.0R13 Some notes on suspension... The f/r ride height is currently tuned for the ZZRs. If I put on the F2000 I'll have to raise the front by 9mm to maintain the rake, which would not be too hard to do at the track. For the R7s though it's a real problem, I'd have to lower the front by 30mm, I'm not even sure that's possible at this point I haven't tried, but that's a huge change. Changing the rear ride height at the track would be a major pain. I already have the tires and wheels for the R7 so I'm committed for now to running them, but a better combination will be 13x6 fronts (same R7 tire) but the taller wheel size on the rear (15x8). This combo will minimize suspension setup change to the ZZR. I had a short look around to see if there are wheel sizes of the same style for 13x6 and 15x8 that would fit but I couldn't find any. I'll dig deeper later this year.
KnifeySpoony Posted Tuesday at 04:08 PM Posted Tuesday at 04:08 PM Thank you. Yeah the ride height/gearing consequences are a concern for me as well. Geometry wise, I'm ok raising my front (currently, my front is quite low, with LCA parallel to ground). Raising the rear is ok too but that would mean a smaller tire and shorter gearing. I'm right at the top of 4th on the longest straights on my 2 home tracks so I'd really prefer not to have to go to 5th (nitpicking I know). Why is rear ride height change an issue for you? Seems just as easy as the front. I'm as low as I can go on my spring perches on rear (actually I've removed the locking perch in able to go as low as I am currently), so any larger diameter tire in rear will require raising the front. I have also considered going to a 15" setup to run A7s in 205/225 but the diameters are quite a bit off. Would require new wingstays and front wings as well. Also I drive my car to the track, so driving on slicks is kinda sketchy. I'm severely grieving the loss of the ZZR in our sizes...
sf4018 Posted Tuesday at 06:48 PM Posted Tuesday at 06:48 PM 2 hours ago, KnifeySpoony said: Thank you. Yeah the ride height/gearing consequences are a concern for me as well. Geometry wise, I'm ok raising my front (currently, my front is quite low, with LCA parallel to ground). Raising the rear is ok too but that would mean a smaller tire and shorter gearing. I'm right at the top of 4th on the longest straights on my 2 home tracks so I'd really prefer not to have to go to 5th (nitpicking I know). Why is rear ride height change an issue for you? Seems just as easy as the front. I'm as low as I can go on my spring perches on rear (actually I've removed the locking perch in able to go as low as I am currently), so any larger diameter tire in rear will require raising the front. I have also considered going to a 15" setup to run A7s in 205/225 but the diameters are quite a bit off. Would require new wingstays and front wings as well. Also I drive my car to the track, so driving on slicks is kinda sketchy. I'm severely grieving the loss of the ZZR in our sizes... The front suspension is easy access, just jack up one side, make the adjustment and repeat for the other side. The rear suspension can only be accessed from underneath. I don't have the trailer space to put in a hydraulic lift so putting it on jack stands is the only option, which is time consuming, especially if I have to repeat a few times. Maybe at the end of the day but then I'm eating into beer time
