Everything posted by MV8
Since the ital axle brkts are not going to work, why not use a six cylinder mustang II/pinto 4x108mm/4.25"pcd 8 inch axle? It's similar to the ital with a drop out center section.
Adding weight applies thrust pressure to the synchros and fork pads which isn't needed or desired beyond selecting the gear.
You might consider using matching bolt pattern wheels and front hubs, or same design wheels with a slightly different spacing bolt pattern spacing to fit the rear. What are the cross over years for bolt patterns and what are they exactly? I don't know off the top of my head.
What year model? Seems to be a common problem for second hand owners and like pulling teeth for original owners. Assembly manuals have harness connector pinouts that you may be able to construct a schematic from. There are a few in the usa7s tech library.
I have just enough width in back to go with an 18' wide (to miss a row of fig trees and leylands around the perimeter with room to grow). I like what this guy did inside an 18x30. Video is about 3 years old and prices are about $1500 more now for the same thing (from a different supplier): Used one of these sensors for about $50 to find my well water line (pump power is routed with the pvc plumbing) then dug to find the depth, since the area will be graded. 24 inches but it is comforting to confirm:
Just a finger wipe will do and help to prevent water from entering. I also grease or oil threads on most anything that isn't a prevailing torque fastener like a nylock.
I guess granada front brakes and dropping the upper control arm shaft down an inch on the unibody. They have power rack and pinion conversions available for these now too. I always disliked the original power system with the tilting pin actuator. Always seemed to over-correct.
I can't tell how bad a shape it is in assembled. For now, I suggest pulling the bolts to check the condition of the bolt shank and hardware between the frame and arm, remove the rust you can access with an abrasive wheel made for removing rust, replace the hardware if corroded, and brush on rustoleum heavily rusted metal primer instead of por15. You can save por for when the parts have been fully restored. Use wheel bearing grease on the bolt shank to protect and prevent seizing to the bush liner. Good hardware can be found from mcmaster, ebay, or even a home improvement store depending on what is needed. Generally grade 5 for SAE or 10.9 for metric.
The evap can should have a hose connection to the engine directly or through a solenoid controlled by the ecu. I think you can cap the tank vent port if using the filler vent port which should be more effective or just use the filler port to make a looped vent pipe without a functioning evap can. There should also be check valves and restrictors in any evap system. I don't know that the evap sys is sourced from an SVT ford. I don't have a cat to look at. Post pics of the system components. Check out the vent routing (no evap can in use) in the pic in this link: https://www.caterhamlotus7.club/forum/techtalk/workshop-notice-371
I like to use pool balls for shift knobs by drilling and epoxying an insert (perhaps a seven ball?) or rod with a bolt-on lever (like a ford application T5). Very comfortable for large hands. Adding weight to a shifter makes no sense to me. Most oem shifters are isolated by rubber in the shaft or mounting flange.
You could make your own for about $20. Buy one inch of 2.5 inch rod from mcmaster but I don't know the method they use to cut it, so truing on a small lathe may be required on one face or just have a machine shop make the spacer.
I take it this has not been driven yet and you took the tank out to clean out the old gas? This must have an evap tank up front. If the end of the fuel hose next to the alternator is not connected to anything, that is probably where it goes but take a pic of wherever it goes.
A similar discussion: https://usa7s.net/ips/topic/13971-wdbs-caterham-super-seven/
I'm thinking that pcd is a relatively new development by momo. Is it six screws? I think the older ones have a larger pcd. Not hard to find spacers for those here that are drilled to accept a variety of six screw wheels with 2.75-2.85" pcd.
Interesting addition to the fleet John. You must be very proud. I kid, I kid! Is joke!
Sharing some information I collected on the heaters used over the years. None interchange without modifications to the car. Left to right, early/90s/late. This info may not be entirely accurate. I've included some pics of my 70's spitfire heater. An early heater could be made using spitfire parts in a new box made of .050 sheet steel or aluminum. The spitfire box has too many openings and the motor/core arrangement is the opposite, so it would be easier and cleaner just to make a new box. The core pipes are longer and curved but they could be shortened to look original or left as-is if the box is installed with the pipes pointing toward the engine. Some early fans have a bladed fan versus a "squirrel cage" with baffles in the box that should be swapped to the new box or fabricated. There may be room in the cowl to fit an early mini cooper heater or similar small heater. It looks like defrost/defog was never a function of the heater box, with a wire element bonded to the windscreen.
- 1
A peek at a portion of the Barber Motorsport Park Museum.
Performance improvement recommendation from... Home Depot!
MV8 replied to Sean's topic in General Tech
You just push whatever the administration decides without question or else. How hard can it be? I can fold quicker than a lawn chair. -
I noticed the cam range was from 2750rpm. May not want to lean much. The extra richness is probably helping to prevent a lower rpm bog from the 48s due to lower port velocity. I think dellorto made a 38 dhla but I'm not sure. A race cam combined with big carbs is tough on low rev driveability. If you consider a carb swap later on, cv carbs (such as a set from a liter bike) are more flexible.
They could try putting the negative on the positive and the positive on the negative but if you asked if I were absolutely positive, I'd say negative. -
I saw the listing for your car. You have plenty of vertical room under the bonnet for a 38 weber or 350cfm holley two barrel and intake. Should be night and day difference in response off idle and mpg, as well as last (less) ring wear.
It's a design issue. If you've ever been waterboarded, you know it can be difficult for air to pass through wet fabric. When moisture is imminent, you could carry a cover with a flange edge to sit over the inlet with a thin layer of foam on top so it doesn't rattle or scratch the underside of the bonnet , but the defog and heat won't work very well, even if you used car cover material in the center. A little water leaking into a running engine is not a problem.
Adjusting the suspension stiffness on a 7?
MV8 replied to philso's topic in General Sevens Discussion
Cockpits are adjustable too, but usually smaller. Depends on current seats. Originals had squabs. -
It's just a short version of a logon I've been using since the late '90s "Miatav8" on miata.net. The image is a TVR Speed 12. They made one road car from the three prototypes for GT1 after the rule change as a heavily modified Cerbera. I might as well have a unicorn avatar, since I don't have one of those either. I just like it.
