Jbrueckh started following Series 2 brake shoes?
A few pictures from our East Coast Lotus Meet - we had FOUR Sevens at Summit Point Raceway... We did several 'touring' laps, during a break in the racing action. A GREAT TIME! --Bob Collum
Timothy Keith-Lucas started following Series 2 brake shoes?
Could someone with this stuff in their head tell me the specification for the brake shoes for a 1962 Series 2 America? They appear very ordinary, but as usual the parts dealers name the more common cars that use them but not the Lotus Seven. Thanks.
Kitcat started following 2023 Caterham 620R S3 $86,000
Posts like this should be illegal:).
- 1 reply
- 1
walstartechnology joined the community
harmoniausaa joined the community
For Sale: Race-Ready 2005 Caterham Seven (SV Chassis/2.3L Cosworth)
BruceBe replied to tozkarao's topic in Cars For Sale
Car has a bunch of stuff not listed in the ad: Tracsport diff (3.91:1) Tracsport racing 5-speed gearbox with all the upgrades (0.87 5th gear) 420R Race springs/dampers Rear race brake upgrade (twin piston AP; 10" discs; prop valve) New MBE 9M4 ECU w/original Cosworth tune and 7K RPM limit New clutch/pressure-plate Cheers, -Bruce -
2024 Caterham 620R. S3. NOT SV(large chasis) The ultimate in high performance Caterham Super 7s. 1200 miles. not tracked. Equipped with 310BHP supercharged motor. Dry sumped motor, huge radiator, oil cooler. Oil cooler for the supercharger and intercooler. 6 Speed Sadev sequential gearbox. Aluminum Bilstein race shocks. Aero front wishbones. 4 piston front calipers with vented discs. Track day exhaust system. Carbon vinyl boot cover.Clear lens pack. Full weather equipment. Vintage Green with Luminous Yellow stripes. Carbon fiber front and rear fenders. Carbon fiber seats with padding. Options include: Heater, Plumbed in fire suppression system, Quick release Momo steering wheel, track day roll bar, LED headlamps, battery master switch, map pocket. Caterham factory Indoor and out door covers. The car is perfect and like new inside and out. New Aluma 14 foot tilt trailer. chassis number: 77105. This is the last Caterham built for the USA at the old Dartford factory so a very historic car. The car is titled in Oregon as 1957 Caterham. This car is RHD. 620s are only suppled in RHD. $86,000. Car can be sold without trailer.
- 1 reply
- 1
We had a long weekend up here so Sunday afternoon we took a drive. We traveled south east about 27 miles on nice sweeping back roads to fill up with fuel. We save on average 32 cents per liter, ($1.12 per US gallon) by buying on the first nations land. We continued back west along some very scenic roads approximately 39 miles to arrive an hour early for the Sunday Cruise Night in Trenton, Ontario. We ate an early meal on the covered outdoor patio at the grill overlooking the parking lot and watched as others started to arrive. It was a great turnout for the first sow of the season with 110 registered cars. Dozens more came and went over the course of the evening. By 7:30-ish we were beat and decided to leave. We drove almost straight north the 14 miles to arrive back at home. In total about 80 sunny, fun filled miles. Tonight, (Monday) was the Brighton Ontario Cruise. The wife spent all today working in the garage to make room for her new to her Spitfire and was too tired so I did this event solo. The first photo was taken at the Trenton show and the second photo at Brighton. I put the plexy wind defectors on just for show. I prefer to drive with the doors on to cut down on the wind.
Not that I know of, because I only ever filled it up with 5 gallons and then added 5 gallons to an empty tank. But it is easier to immediately stop the flow than a can that's tipped over. The dispensing lever on top is spring-loaded.
Does it shut off at a certain level?
tozkarao started following For Sale: Race-Ready 2005 Caterham Seven (SV Chassis/2.3L Cosworth)
This factory-built Caterham Seven is fully prepped, track-proven, and built to be fast, reliable, and safe. It is ready to hit the grid and be competitive immediately. Price: $40K Key Specs: Chassis: 2005 SV Imperial Engine: 2.3L Cosworth/Duratec (200 HP) Drivetrain: 5-speed gearbox with Limited-Slip Differential Cooling/Oiling: CSR-spec (Dry sump, dual fans, high-capacity radiator with proper ducting) Handling/Stopping: Race-spec suspension and upgraded AP Racing brakes Safety Equipment: Full FIA-certified (Superlight) roll cage Fire suppression system Tillett racing seats FIA Schroth 6-point harnesses Battery disconnect switch Race footage: (See channel for more) https://youtu.be/HwWyLG0Oq2Y?si=PZ6eIUAwzDZIxrJI Serious inquiries only. Please reach out to discuss details or arrange a viewing. (Located in Bellevue, WA)
William is correct with the post and files. I grabbed the STL from there, then uploaded and ordered through Xometry (a contract 3d print company). I had them printed in Nylon 6 CF (carbon fiber), solid infill. It was about $50 shipped. They came out pretty much perfect. I did need to widen the hole for the door post - pretty minor!
@jmaz STLs here: https://drive.google.com/open?id=1-N1xAZflfujHWm8XC1FcDFjQnePVB3mI Found here: https://www.caterham7diaries.com/post/eccles-mirror-mounts Print it in something that can handle UV from the sun!
What 3D print model did you use for the Spa mirrors? Is it one that you can and are willing to share? What type of print filament did you use? I figured I'd try to get the Eccles version mounts from somewhere, but no idea how long that might take. Ordering anything from the UK these days seems to be a crap shoot, what with tariffs, backlogs, etc.
tozkarao joined the community
Here are the weights of Caterham's SV Track Day Roll Bar and Track Day Rollcage measured during a recent swap: 18.2 lb / 8.3 kg for the Roll Bar 26.6 lb / 12.1 kb for the Rollcage Difference between the two is 8.4 lb or 3.8 kg. The swap was straightforward but difficult as the cage's mount points didn't align well with the chassis, and the carbon fiber sill protectors must be shortened or replaced. If there is interest I'll be happy to elaborate, but my advice is only do this if you truly feel you need the cage. I'm selling the dedicated track car so felt replacing the roll bar with a cage made sense for me, but it wasn't long in the process before I was thinking about just keeping the track car.
- 2
CBuff started following Need Air Speed Seensor
Would something like this work? https://www.amazon.com/BTMETER-Travel-Protect-Handheld-Anemometer/dp/B07JVNYNB3/ref=sr_1_1_sspa?crid=34QWL1KG36VVG&dib=eyJ2IjoiMSJ9.Hku2tRKa0IcyYiLdSpw_rBTmZmcoVh17yuDdzcO5YBIO0iCPodLACS4BuzC2XbBcAOdcKFXeuZ0RgoNoj7IEAi1ZW5mCpmNjkiCbRM1SkFrL-cnJbkYqt2MuDMfVZTuN2JWDBTqoisU9AFext8uSIgiXC45V3rtRuLonbpHZ1DseOSg_vkkQssXCrYQvowezbCGCBp1-X4RFk2KsZG40rP2wknEKwKmEWv1Gg1y5hepoy7PWvb_68p_hDW4h0UdE92aId7AGsBW7LFyFsIoAXje3JAAFRZYugxKDpcFxPGI.h7USq8Cp-pyGHminHej30D6fkaC7LETzdAFoxBBsl04&dib_tag=se&keywords=wireless%2Bair%2Bflow%2Bmeter&qid=1779142854&s=industrial&sprefix=wireless%2Bair%2Bflow%2Bmeter%2Cindustrial%2C120&sr=1-1-spons&sp_csd=d2lkZ2V0TmFtZT1zcF9hdGY&th=1
Got my car back on the road just in time for Free Bucket Weekend! Now that all the chassis hardware is torqued, time for a wash...
I'll take any excuse I can get to link to the definitive article about the Caterham's exploits at the Nurburgring 24 Hours. I'm surprised the special edition didn't have red wings, considering the red rollbar seems to be a tribute... https://www.autosport.com/general/news/when-caterham-enjoyed-its-finest-hour-in-improbable-surroundings/10341200/
My one last (for now) thing to add is when I imagined that I'd be filling gas up at home more often, I splurged on one of these. A gas can that you don't need to tip to control the flow. So luxurious! (I've used it precisely once) https://www.surecanusa.com/product-page/5-gallon-gasoline-surecan
IamScotticus started following Need Air Speed Seensor
Could you guys recommend a data logging air speed / flow sensor that is small and self contained that can be placed directly in front of a 7 coolant radiator to measure airflow rates at speed? Data logging because I will probably send it to a volunteer to record the data. So why not just hold a meter out the window of my own car? I suspect the airflow inside a 7 nose is not as linear as direct outside air. I wish to establish a baseline airflow to simulate in my garage for tuning. I also suspect nose cone airflow to be surprisingly deficient requiring additional baffling for effective cooling. As Lotus already accounted for on the S2s with the standard radiator air dam. I don't know why Cat didn't continue the practice. Anyway, I don't have time to shop for this myself. Help!
Thanks Scott. It's amazing to find that a number of car owners have asked this question on the web and there seems to be no conclusive answer. Even Ai suggests on older (vintage) cars, valve stem seals are not necessary, but it doesn't mention bronze guides. "I took a drive the other day, and parked the car to take a stroll. Came back to my car and a note on the windshield said "Parking Fine". It's great when someone congratulates you on your driving abilities".
11Budlite replied to Croc's topic in Cars For Sale
New listing on BaT: https://bringatrailer.com/listing/1966-lotus-super-seven/?utm_source=Iterable&utm_medium=email&utm_campaign=Disambiguation_Update -
JWX, Sure, I would take them to your choice of shipper after the funds are cleared. As an example, but within the US a few years back, delivered cycle fende.sr to a shipper picked by the seller and paid for completely by the seller. Don't know anything about shipping from San Diego to Canada. I have them advertised for $500 for the pair, see advert in this forum. Also have many styles of bonnet clips if you might be interested. Wayne "super7guy7@yahoo.com"
LocostBuilder joined the community
nuraslimdetoxxusaa joined the community
Ha! I think I’ll wait a bit and decide if like the solid yellow first… in the interim, installed CaterLEDs for the 3rd brake light and also 3D printed some mirror mounts for the Spa mirrors. I think both look great!
a wrap can do it
Need to report that this new mirror is quite good. Sharp image, remarkably reduced vibrations, and I like the blue tint. That stock mirror might work for a golf cart but guys there is a better way.
