JohnCh
Administrators
Everything posted by JohnCh
  1. Carbon NV makes them at £280 per pair but I've never seen feedback on quality or fit. https://www.carbon-nv.co.uk/products.html
  2. I've contemplated this design when building my car and had planned to speak with Oxted Trimming, who make the sidescreens, to see if it's feasible. It certainly seems a far more functional and elegant design, but it may require reinforcement as MV8 suggests. I've put off speaking with them given I'm finding the SV with lowered floors isn't quite as obnoxious as my memories of S3s with standard floors. So far, it's been acceptable. Not as good as the Westfield with oversized wind deflectors, but not so bad that I feel I need a fix.
  3. Josh at Rocky Mountain Caterham also stocks parts. If the left lens is original to the car, you might want to consider buying a pair to ensure they match. Micro scratches over the years can really dull a lens, making the new one stand out by comparison. Been there, done that, and had to pay for shipping twice.
  4. It's been Guinness and creative swearing for me. Although typically not in that order.
  5. I'm running Racetech mechanical gauges on the Westfield for water temp, oil temp, and oil pressure and like them, but opted for an AiM display on the Caterham. I'd prefer to keep that minimalist dash aesthetic and not add any standalone gauges. The good news is the pigtail was the issue. A multimeter confirmed the 12v+ wire had a problem, showing fluctuating positive resistance vs 0.00 ohms for the other two wires. It's most likely a failed crimp at the plug end.
  6. @Tempesto did it log correctly in the past? Have you already checked Emerald's site to ensure you are using the correct software version for the model fitted? Assuming yes to both, have you tried pinging Emerald? They can be a little slow to respond these days and it may take a few attempts, but Karl is very helpful once you get a hold of him.
  7. If you are ok running a square setup, Toyo's site shows the RR comes in 205/60-13. https://www.toyotires.com/product/proxes-rr/
  8. You clearly don't grasp the criticality of instant gratification Hopefully, the weather cooperates the week it arrives, and the car meets or exceeds all your expectations.
  9. Congratulations! Any idea yet of when you'll be in the driver's seat?
  10. I did a 40 mile solo blat yesterday and 50 mile blat with @Pokey today to my favorite road in the area. Oil pressure readings remained solid, so hopefully the pigtail was the cause. These were my first opportunities to properly drive the car since completion. The alignment and mapping are done, the low fuel pick up issue is sorted, there were no oil pressure sensor issues to ratchet up my paranoia, and the roads were dry. I'm still not pushing to redline or putting my foot to floor and holding it there, but have taken a few journeys to >7000 rpm, and have pushed it to about 80% throttle for momentary spurts in gear. I'm also more comfortable starting to explore the handling. Although, not perfect, I am beginning to warm up to the Caterham. The engine is really, really nice, and the ride and traction on bumpy roads is surprisingly good. Without driving it back-to-back with a stock 420R, I can't yet comment if this is a testament to the CORE dampers or Meteor Motorsports spring rates, but it is much better in this regard than I anticipated. I need to spend time relearning everything I forgot over the Winter about tuning with Easimap. The engine runs great, except for a few minor glitches at very low rpms. Specifically, when pulling away reasonably hard from a stop, there is a slight flat spot. I suspect the map at very low rpm but heavier load sites is either too rich or too lean and I'll need to log it to identify the needed tweak. Also, based on lambda dash readings, it appears a little too rich at low rpm, very light throttle conditions. It's not noticeable from the driver's seat, but I'm probably burning more fuel than necessary when driving at a steady pace. My only picture from today, taken while performing the obligatory stop for coffee. This is, after all, the Pacific Northwest. -John
  11. This is @peregrinemotors car which is also lister here:
  12. Given it's a new car, has Tom at Birkin given you recommendations for a package that works? If not, or if you are looking for options, a good starting point to identify parts you may need or wish to upgrade is the Raceline price sheet. It's pretty comprehensive list of parts required based on spec. https://www.raceline.co.uk/pdf/DURATEC_2000cc_2021.pdf Chris and Peter are very helpful and have quality parts, but they struggle with email. Always call whenever possible. https://www.raceline.co.uk/ Another option is SBD. As with Raceline, calling is always the best bet. https://sbdmotorsport.co.uk/ -John
  13. I thought the oil pressure reading issue was resolved with the new sensor; however, when starting the car today for a quick lunchtime blat, oil pressure was on zero. Again. No amount of blipping the throttle or changing idle speeds made a difference. With the engine still running, I got out, reached under the car, and shook the pigtail immediately behind the plug that attaches to the sensor. Suddenly the oil pressure reading was normal and remained that way for the drive. Although the replacement sensor came with a new pigtail, I opted to keep the original in place, making only one change at a time until the root cause was clearly identified. I'm glad I took that approach. I'll swap in the new pigtail and start monitoring things again this weekend and may also attempt to disassemble the old plug to look for a connection issue.
  14. I've enjoyed your other books and just bought this one despite the fact it features a front wheel drive car on the cover
  15. Echoing the above, recent history has shown Caterham's hold their value well, but there is no way to predict that will remain true in the future, particularly in 10+ years. If, however, the objective is to only own the car for a year or two with minimal cost of ownership over that period, then that seems a reasonable risk. But risk is always present in this type of situation. You need to be comfortable with that. Reliability is good, but like resale value, there is no certainty that will be your experience with this specific car. Pick the most reliable new car brand out there and some owners will still have issues, hence the reason there are still warranty and Lemon Law claims. One good thing about the Caterham, or any se7en, is that for the most part, they are easy to work on and they lack many of the modern convenience and safety features that can go wrong in new cars. i.e. the set of things that can break is much less. Although you didn't ask about Josh, I will say that in my dealings with him over the past few years, he has always impressed me. Very responsive, helpful, and knowledgeable. I would never hesitate to buy from him. Oh, and one last thing. These cars are life changing. They are on an entirely different level of engagement than other cars and can reset your perspective on driving fun. They are worth the risk
  16. If anyone is having issues posting images consistently, please review the first three items in the following help guide then PM me if you are still having trouble. If you feel it's helpful, please start a dedicated thread on this topic in the Issues & Help forum. This completes our thread drift. Now back to the discussion.
  17. @Lotus_Repair interesting car. BTW I rotated your images. Please see this help guide on why it happens and how to fix it in the future. Thanks, John
  18. It might be worth calling RD Enterprises and Dave Bean. They both offer kits for the twincam that utilize smaller, modern alternators. Given the engine blocks are the same, there's a good chance it is bolt on to a crossflow, but they should know. BTW I have the RD kit on my Elan. Works great.
  19. Just found this video that has some good shots of the car, including under bonnet. BTW I've found references of >1000hp, 1300hp, and 1400hp. I'm not sure if that indicates engine evolution, or just guesstimates by various people. Regardless, the actual power level seems to be sufficient. -John
  20. From what I've read elsewhere, the car has 1400hp, which is hard to comprehend in such a light car. There is some onboard footage here. https://fb.watch/dxNt_84qaV/ Once he gets on it, the acceleration is mind blowing.
  21. In that case, treat the following as a form of mild torment. It's something I put together when investigating regearing options. Stock MX5 Quaife 1 Quaife 2 1st 3.136 2.564 2.345 2nd 1.888 1.67 1.544 3rd 1.33 1.277 1.222 4th 1 1 5th 0.814 0.794 0.868
  22. Another option I researched a couple of years ago is a Quaife close ratio gear set. They make two for the Miata, both of which are on the tall side, although if needed that can be offset with a shorter ring & pinion from Turner Motorsports. Unfortunately, real world feedback on the gear set was sparse when I looked into it, and I have yet to hear of anyone running it in a Caterham. You can be the first
  23. I think you can use the advance setting on the 123 if the distributor body is positioned for advance >0 deg; however, as MV8 notes, the norm is to affix the distributor at 0 deg, then input the actual timing curve into the software. As an example, below is the curve for my twincam. Note: advance = 0 deg, and the table starts at 13 deg at 500 rpm. BTW this was done on the dyno to optimize the curve for my specific engine and local fuel. Well worth the money as torque notably increased everywhere.
  24. Keep in mind that although the 420R has been modernized in a few areas (e.g. engine, heated windscreen, stiffer frame, increased cabin space), it is still a design that dates back nearly 70 years. Even in 1957, the Seven wasn't considered a paragon of comfort or NVH control. Freeway and city driving are not its forte, however, those are often necessary evils to reach the good roads. It's something we just need to accept. Fortunately, there are ways to mitigate some discomforts. Freeway journeys? Put on the sidescreens. They significantly reduce the buffeting. Trips in really hot sun, particularly when you will be driving slowly at times with no airflow through the cabin? Get a half hood. It's a giant sunshade, and as a bonus, it also helps with buffeting. Mental fatigue from driving on busy freeways or in cities is real – you are always on the alert for texting, latte swilling SUV drivers. Short of becoming a Zen master, there's not much you can do to minimize it, but you can treat the symptoms with a strong beverage once you arrive at your destination. Bottom line, this is not a normal car. But if it were, it wouldn't be so much fun. Learn to embrace the suck and enjoy the corners.
  25. I had hoped that's where the car was headed. Glad you two were able to strike a deal.
