fastg
Everything posted by fastg
  1. Sorry is this has been posted before, a search could not find anything, cut and paste from the Locost list. https://heeltread.com/collections/british-charm/products/seven-socks Graham * Socks sold fully assembled, not available as a kit.
  2. Carl is correct, reading plugs is a black art. Reading old plugs is just about impossible. Drag racing is just about the only sport were plug reading is used, but they shut the engine down at full throttle and coast into the return lane. You can tell general engine health, burning oil, coolant that sort of thing. If you want to know how your jetting is install a wide band sensor, you will learn more in one drive around the block that you will spending weeks swapping jets. Gunson (the ColourTune people) used to make a self contained unit that you could plug into a power source and put a flexy hose in the exhaust pipe, worked great. Graham
  3. Thanks for the video, that helped a lot. Very cool car. Graham
  4. Feynmanfan, I have been looking at the Aluma for a while, I would be very interested in your mods. Graham
  5. I used these, been on the car for years, many wheel changes without an issue, hold torque great. https://www.advanced-autosports.com/search?q=Studs Graham
  6. I also recommend you try the Locost list, There is an amazing amount of knowledge on that site. But you might want to talk to Jack at Kinetic Vehicles. https://www.kineticvehicles.com/windshield.html Graham
  7. I wish I had a welder at his age:) http://locostusa.com/forums/viewtopic.php?f=40&t=20781&sid=051bb13b493abf59458728787d461c4e Graham
  8. Found this on the Locost list. http://locostusa.com/forums/viewtopic.php?f=40&t=20781&sid=dbe5edc710d36124ab087bc79f946a6d Graham
  9. If you have an OBD 2 port you can data log, I use a OBDLink MX+ Blue tooth adapter. It syncs up well with the https://racechrono.com/ app I use. You will be able to log all the OBD parameters, not everything, but a lot of interesting stuff. Engine temp, throttle position, coolant temp, IAT, speed... Graham
  10. That looks like a great package, a lot more than a MegaJolt style setup that really only replaces your distributor. This setup is a full engine management setup just without the fuel injection. Anything you can to to get rid of a distributor is good. Graham
  11. I ran a MegaJolt on a V8. Simple setup using loss spark Ford EDIS coils. Simple to wire and setup, and removed the distributor. A win win. Graham
  12. I have never heard of Methanol/water injection as a strategy to lower engine temp. Its goal is to reduce inlet air temp, boost octane and reduce detonation. Often used as a replacement for a an intercooler. For more information https://en.wikipedia.org/wiki/Water_injection_(engine) Graham
  13. It's going to be an expensive exercise for a situation you think might happen. You will need a fully E85 compatible fuel system, a E85 programmable ECU, most people use the GM Flex Fuel sensor. Then your going to have to have it custom mapped for both regular gas and E85. https://www.amazon.com/ACDelco-13577429-Original-Equipment-Sensor/dp/B01GQR9C5O Graham
  14. Beware E85 is not available everywhere, Here in MD I have never seen an E85 pump. I was at a track day I think VIR and the guys had to bring all there gas with them for the entire weekend. Maryland only has 7 station, VA only has one in the state! Graham
  15. AAA worked for me before I had a trailer. Broke a lower control arm. AAA flat bed towed it home. I have looked at the Aluma trailers even looked into local dealers. If you line that with a Serpent Express cover you might have the perfect solution http://serpentexpress.com/ Graham
  16. Article in Forbes https://www.forbes.com/sites/peterlyon/2021/04/07/british-icon-caterham-cars-acquired-by-japanese-automotive-group/?sh=7dd288557783 "And what lies ahead for VT Holdings? While the Japan-based firm will now manage the day to day running of the business as Caterham cars are designed and built in the U.K., we can expect to see electric versions joining the lineup by 2030." Graham
  17. Spray brake cleaner around the carbs/manifold, if the engine revs change you have vacuum leak Graham
  18. Is the air filter setup stock? For that matter is the exhaust stock? Graham
  19. as I think someone said of your fuel pump was under peforming your run would lean out during the run, your afr stays pretty stable, so I think your just running lean. A plug chop with old already colored old plugs may not tell you what you want to know. Graham
  20. A miata is a computer controlled engine, so yes you will need the ecu and necessary electronics. If you swap to a megasquirt you can delete the mass airflow sensor. Graham
  21. escondidoron in correct, Hydraulics can are counter intuitive. It all about areas not diameter's. If you have a master cylinder that has a 1 Square Inch piston and you apply 100 pounds pressure to the pedal your hydraulic system is pressurized to 100psi. So if the area of the caliper pistons pressing on the pads is 2 Square Inch you have 200 pounds pressure at the pads. If you put in a larger master cylinder lets say 2 Square Inch but you still have the same 100 pounds pressure on the pedal you now only have 50psi in your system, with the same 2 square inch caliper pistons you only have 100psi at the pads. You have just halved your braking pressure. But your pedal will feel a lot firmer as it will take 1/2 the pedal travel to move the pads the same amount. Graham
  22. I tried to take a picture on my Locost but it's up on jack stands so the suspension is in droop. But here is a picture you can see the upward slope of the top a-arm. A better place to ask your question is the Locost forum, lots of very knowledgeable people on suspension design, check out http://locostusa.com/forums/ http://www.mglocost.com/images/big/lfcorner.jpg
  23. If you have the a-arms parallel the wheel move directly up and down, the camber will remain the same, that is very bad, because as the chassis rolls in the turns you will get increasing positive camber, not good. So you want the upper control arm lower by the chassis, that will increase the negative camber as the wheel moves up. That will increase in the positive camber that will be offset by the chassis rolling. So if the angles are correct you will still have negative camber throughout the corner. Graham
  24. The new track focused Birkin Tom was driving at NJMP 2020 was a stunning looking car. Inboard shock and a very neat inboard anti roll bar setup. I loved the one piece hood that went right up to the dash so all the elecrickery was easy to work on. Graham
