32 minutes ago, Scott_ said:
Car pickup day for the Superlight R400 SV.  Left from Raleigh for Virginia at 6:30am, back in Raleigh by noon.  Dropped off trailer and then to DMV to stand in line for thirty minutes for title work and a 10 day tag.  Back to the house with the tag and then drove an hour in the countryside.
Scott
Congratulations! At some point, I'd love to hear your thoughts on how it compares to your old car given all the differences (chassis, engine, gearbox, wheel size, etc.)
On 9/10/2026 at 1:51 AM, Croc said:
Very very wet…
Hey, what cage is this ?
Its the easy ingress track day but with the outside bar by the door for lateral impact
7 hours ago, Xhilr8n said:
On 9/12/2026 at 11:11 PM, pethier said:
It's not the entire car.  Just something that will become a part of the CSR.
Tillett B6 Seat
Standard Width
Edges off 40cm
Carbon Fiber
Bottom mounted
Special Order Item
Thanks.   I'll start a new owner's thread but it's a completely different animal.  The 1.8VVC in the 99 is a great engine in a very light car, Ford Type 9 five speed, was RHD, and was running on 13" wheels.  The R400 has a Titan LSD, wide track, 6 speed, and probably 50-60 more HP with the 2.0l Duratec and Kent cams.   The SV has 15" wheels I have to say right now I prefer the 13" staggered setup on the '99.   The clutch on the '99 was progressive and had long throw, the R400 clutch in my car is more like an on/off switch and took some getting used to.
The SV is noticeably bigger than the S3. The '99 had a lowered driver's floor.   I had never sat in a SV.   This  one has lowered floors.    I don't have the seat all the way back in this car.  Seems like much more room for legs and feet and I can probably get away with not wearing driving shoes in the SV.   The '99 had a four point harnesses  and the R400 has five point harnesses.
I bought a regular rollbar from a member here but will likely keep the cage on for now.  (I may be doing a track day in October up at VIR.)  The cage is not factory Caterham and was built off a track day rollbar by a race shop.
I loved the look of my '99.  I also really love the look of the livery on the Superlight R400.   This has what they called the Lotus anniversary paint scheme on it and it matches the Caterham F1 livery from the 2012-2014 period.  It also matches the R600 promotional photos.
Scott
Edited by Scott_
  • Like 6
Its the standard track day cage I purchased from Caterham 3 years ago.  At that time this option was configured as the race roll cage with an easy entry option.  420 SV sized.  Caterham seemed to tinker with the designs since then so that it is not offered on the website but I would be asking if they can do it as I know an acquaintance's UK car recently got the same cage 3 months ago.  .
TYSM. Good to know. I will ask caterham
Me following Charlie to Helper, Utah, at LUG 2026.   Only two Sevens among the 170 or so cars.  Good times, great people.
  • Like 4
Scott
You are going to love it if it is dialed in just right....  I sold my 2L Vaux Cat for a R400 sl.... night and day dif... great platform
7 hours ago, Croc said:
It’s the standard track day cage I purchased from Caterham 3 years ago.  At that time this option was configured as the race roll cage with an easy entry option.  420 SV sized.  Caterham seemed to tinker with the designs since then so that it is not offered on the website but I would be asking if they can do it as I know an acquaintance's UK car recently got the same cage 3 months ago.  .
Does this/your cage allows to mount a windscreen ?
Should do since it is a standard condition of Academy series that you run a full FIA cage with windscreen and side doors - your dealer should be able to get Caterham to confirm this.
With the 9inch high back window the turbulence (up to 70 mph) was really not an issue...ball cap not down and tight
  • Like 6
Have some beautiful warm days actually in Germany so still without doors
  • Like 6
1. First place in local British car show!
2. Recent drive outside Albuquerque, NM
3. A Caterham buddy and I, preparing for a driveout
  • Like 5
  • Thanks 2
On 9/26/2026 at 2:51 PM, toldfield said:
After we arrived in Helper, UT.
Photo credit:  Phil Ethier
A third one showed up at the Funkhana:
IMG_7126
  • Like 4
Sevens terrorize Woods Hole. None of them are mine -- I had the Elan out this time.
  • Like 6
Temps in the 70s, lots of sunshine, had to get out and enjoy the day! Highway 96 at I-40 has lots of curves and elevation change as it follows a ridge around Center Hill Lake. Great day to be out.
  • Like 5
Thanks Phil.
